Adam's annoying ass green 620
Dash and surround-not so hot.
Gauges and bezel-spot on.
Need anything else.
Calling a scrapper tomorrow or Saturday.
Need anything else.
- Eagle_Adam
turn signal lenses and housings for the drivers side
- Eagle_Adam
and honestly anything else you wanna pull
im always up for spare parts
Which ones? Front? Rear?Eagle_Adam wrote:turn signal lenses and housings for the drivers side
PDXMatt took the front ones.
- Eagle_Adam
i need both
I have a perfect set of tail lights. Sides are all fuckered. Fronts are MIA.Eagle_Adam wrote:i need both
I'll see what is in the parts boxes. I have some 620 stuff at in-laws house also.
Update-the gauge bezel is cracked. Went to go remove it a minute ago Big crack!
It was at the perfect angle that I didnt see it last night when I went and peaked.
- Eagle_Adam
figures, they always crack.....
lemme know what you have, for now im gunna hit the JY later today so my dads truck is ready for blue lake
- Eagle_Adam
yup, i talked to him
- Eagle_Adam
- Eagle_Adam
- Eagle_Adam
any now we rewind to before the show....
when i had almost no brakes and a failed NLSV....
here is the failed valve making sounds it shouldn't, ive checked 3 other trucks. All their valves are silent.....
VID:
http://s1356.photobucket.com/user/Eagle ... 2.mp4.html
VID:
- Eagle_Adam
so prior to blue lake i went to town with a few friends and tore out the failing valve, bypassed it, and put in a working 78 IR 620 alt so i could safely make it to the show and back
- Eagle_Adam
one thing at a time!
ya right
first things first
this block had 3 lines going to it
1 - from the MC to the block
2 - from the block to the valve i deleted
you connect two of the lines and delete the other
like this
then you move to the valve of doom that i hate sooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo MUCH!!!!!!!!!
its a simple delete here too, the block that just got deleted left you with 2 lines going to the NLSV. The one connected in the pic above you keep the other one is deleted.
then a piece of hard line and a few fittings like so
and BAM! DONE
ya right
first things first
like this
and BAM! DONE
- Eagle_Adam
after the valve was gone, we bled the system and came to the conclusion my brakes were %25 better....
But the MC was bad :/
i had already arranged to pick up a 15/16ths MC at blue lake, so when i got home and the after party went home me, banner, and laecaon got started on the MC swap and fluid flush
but first! pics of the blue lake after party!
- Eagle_Adam
the new 15/16th's MC!!!!
the swap was strait forward
the old MC
BTW an old rubber floor mat can save your paint when doing something like this
the new MC installed
BAM! back to stopping!!!!!!
I do need to install a proportioning valve tho, then i can do the rear disc swap!!!!
the old MC
You can install inline residual pressure valves that can be removed when doing the rear swap.
No need to wire in a bulky PV then wire back.
Look at the bottom of this link. The red ones. http://www.wilwood.com/MasterCylinders/ ... alves.aspx
Thats what those are for. The 15/16" has equal prop valves.
All 4 hitting at same time.
The 10lb. valve will wait till the system pressurizes then activate the back.
2lbs for front, and now 10lbs for rear, vs 2lbs as of current.
These things are money.
