Page 32 of 46
Posted: Tue May 26, 2015 9:20 pm
by draker
Took it for another 10 mile test drive. It seemed to do really well. Plan is to get a muffler on it.. maybe get it aligned. Then put miles on it before canby.
I've got a bunch of small things I need to take care of.
Posted: Tue May 26, 2015 9:29 pm
by draker
[ ]Install front and rear bumper
[ ]Install mirrors
[ ]Fix Headlights
[ ]Front wheel bearings
[ ]Install IR alternator
[ ]Clean headliner
[ ]Clean interior
[ ]Adjust weber
[ ]Glove box vibration issue
[ ]Install carpet in back seat riser area
[ ]Check oil pressure
[ ]Muffler/Exhaust
[ ]Clean wheels
[ ]Install chrome windshield strip
[ ]Wipe all rubber/vinyl with treatment
[ ]Spray bare metal spots with zero rust
[ ]Repair rust rot on passenger quarter
[ ]Find solution to reverse light switch clearance issue
[ ] Get all marker lights working
Posted: Tue May 26, 2015 9:32 pm
I like the new height. Its perfect.
Posted: Tue May 26, 2015 9:33 pm
by draker
DRIVEN » Sun May 24, 2015 6:34 am wrote:Can you grind down the body (nut portion) so it screws in deeper?
I am going to try this!!
Great idea.. I have nothing to lose at this point.
Posted: Tue May 26, 2015 9:36 pm
by draker
Laecaon » Tue May 26, 2015 10:32 pm wrote:I like the new height. Its perfect.
Thanks! No more bottoming out the struts at this height either. A bit of rake though... but it is what it is. I'll probably realign it in my garage this weekend.
Posted: Tue May 26, 2015 9:58 pm
Ghetto style, chuck the threads in a drill, clamp the drill trigger to spin. Take a cut off wheel and grind off the materia, makes it even all the way aroundl. I have done this a few times...
Posted: Wed May 27, 2015 5:12 am
Works fine for me. That's the exact method we use to resurface plungers on Denso starters at work when we replace contacts.
Posted: Thu May 28, 2015 9:41 pm
by draker
Posted: Thu May 28, 2015 9:53 pm
I dislike bondo work and sanding, I am no good at it, I keep doing the same spot over and over and it's no better.
I find people to do it, but by the end of the job they lose interest in the job and don't work on it anymore, so it sits, I call them artists, they work when they feel like it, which isn't very often.
Posted: Thu May 28, 2015 10:04 pm
by draker
It's not fun.. so much work. I've got a few more rounds of filler and blocking and priming and blocking to go before the color goes on. Then it needs color sanded... uhg.
Posted: Sun May 31, 2015 10:29 pm
by draker
Posted: Tue Jun 02, 2015 9:00 pm
by draker
Installed new T/C rod bushings and button top hardware on the camber plates for more adjustability without hacking the towers.
Posted: Tue Jun 02, 2015 9:03 pm
by draker
Getting prepped to get it aligned. All steering components are new. All bushings have been replaced.
Posted: Tue Jun 02, 2015 9:26 pm
Haha man i wish I could align it for you!!
Come to astoria, i do it.
Posted: Wed Jun 03, 2015 9:15 pm
by draker
Lol my tires would be bald by the time I get there. I checked the toe today. After replacing the tc bushings and lowering a bit more I am 1/8th" total toe out. Not good. If I have time I'll adjust.. otherwise it's gonna drive 15 miles. Probably not a huge deal.
Posted: Fri Jun 05, 2015 11:54 am
by draker
[ ]Install mirrors
[ ]Clean wheels
[ ] Alignment
[ ]Fix Headlights
[ ]Adjust weber
Posted: Fri Jun 05, 2015 12:18 pm
by draker
Posted: Fri Jun 05, 2015 12:22 pm
by draker
The low pro switch didn't work. It was about 3mm to short. I tried to grind the face of the switch a little for more clearance and almost immediately cut into the guts of it. Not enough extra meat on it to modify. So I grabbed an old switch and pushed out the tunnel a bit. It works. Now I have reverse lights.
Posted: Wed Jun 10, 2015 9:58 am
by draker
Fixed the dome light and dash lights. I can see!!!!
No luck fixing the front marker lights though. I have a bunch of them.. but all the bulbs are rusted into their sockets.. and the housings are trash.... I'll be looking for some at the show!
Posted: Tue Jun 23, 2015 3:08 pm
by draker
SU's have been dropped off at Z therapy.
Just bought a new collapsible antenna from thailand. Hope it's worth a shit..
The car has been great! I've put about 400 miles on it. It gets a little warm in 80+ weather. I gotta figure that one out. My guess is the radiator is clogged with shit. I've flushed it like a mofo and it was dirty. But the coolant is back to rust color after putting miles on it.
