Page 32 of 66
Re: soon to be LZ2.3 521 :)
Posted: Sun Jun 08, 2014 8:22 pm
by uberkevin
Wayno I was tthinking that same thing...
I also thought about just changing lash pads so I did so and was able to get the right clearance. However this is still just a temporary fix.
Lucky this is Rons motor and not mine. He said head get it all checked out and maybe fixed if it can be. I told him to go with bigger valves! Ha
I'll only drive my truck a day like this.. I hope.. I'll take this head off tomorrow after work and slap on the other u67 'one intended to go on lz23' drive it this way tell everything is needed to put the Lz in the 521.. :)
Posted: Sun Jun 08, 2014 8:23 pm
wayno wrote:and you also likely have your foot deep into the pedal all the time
Yep.
Posted: Sun Jun 08, 2014 8:24 pm
by uberkevin
Mild cam???
Thinking about keeping..
Shhhhhhhh..
Posted: Sun Jun 08, 2014 8:26 pm
by uberkevin
Yep.
I try not to...
I try to get away from large amounts of cars..
Posted: Sun Jun 08, 2014 8:42 pm
The reason I know about this is because my foot is always deep into the pedal all the time in the work truck, I didn't even get a year out of my new head before it had to be rebuilt again, the machinist and I have talked about this more than once, it will still happen, just much slower with hardened seats.
Using thinner lash pads will also temporarily fix you clearance issue, the follower will just ride the cam lobe in a different place, but your living on borrowed time now, the valve spring is looser, so it will float easier now on that valve, and it will sink faster and faster also.
Posted: Sun Jun 08, 2014 8:58 pm
by uberkevin
So I do know a little.
It took me a while to realize what may be going on.
But this is why I'll only be driving the truck tomorrow, then swaping head.. Damn. Hope this other one is fine haha.
Posted: Mon Jun 09, 2014 4:21 pm
by uberkevin
Don't think I'll get the head off today.. Tomorrow should be a better day to do it.
Posted: Tue Jun 10, 2014 3:35 pm
by uberkevin
Okay I've got the tool needed.
Really hope I can swap the head tonight. And drive the truck tomorrow.
Kinda a lot to do also gotta mow one yard before sprinklers turn on at 830.
Shiiiit
Posted: Tue Jun 10, 2014 3:37 pm
chain tool?
I used a piece of 1x2 wood or some shit... drilled hole, tied rope to it. haven't dropped a chain since. Best part ,free!
Posted: Tue Jun 10, 2014 3:54 pm
by uberkevin
Yeah chain tool. I've been borrowing flatcats when I need one.
Should get my own.
I was going to make one lastnight but I don't have the tools to do so.
I've read a few time about people using a hose or like you said make your own out if wood. Witch is what I was going to do.
Thought I should wait tho.
Posted: Tue Jun 10, 2014 6:40 pm
I was using flexible, flat irrigation hose on the KA I just finished for Lance.
Folded it a few times-stuffed it like a slutty cheerleader at the homecoming party.
Posted: Tue Jun 10, 2014 8:12 pm
lol yup. I used a skil saw to make one cut on mine, was done... Well, and a drill for the hole for the rope.
Posted: Tue Jun 10, 2014 8:37 pm
by uberkevin
Got the head off. Can't really see anything, yet. I'll look at it more later.
I'm just cleaning the block to put the HG on. Then the other U67, seem like if I work tell midnight I should have it running.
However... I'm hungry cuz I haven't eaten anything. So I'm taking a beeeezzzong hit! And get me some food... I'llpost ppicture of the head.
Posted: Tue Jun 10, 2014 10:00 pm
Yeah lemmy see the head, even if its just the tip... lolwut
Posted: Tue Jun 10, 2014 10:02 pm
by uberkevin
Got the head on. Water hooked up carbs an Mani back on.
Need to double check my valve lash on this head.
Posted: Tue Jun 10, 2014 10:10 pm
head swap was quick dude. jesus..
When I swap heads i spend a good 2-3 hours or so scraping the fucking head surface off and block surface :| Probably a bit excessive.
Posted: Tue Jun 10, 2014 10:11 pm
Hahahaha. Because Kevin steals shop supplies from my work.
Brand new yellow Roloc discs FTW.
Posted: Tue Jun 10, 2014 10:19 pm
flatcat19 wrote:Hahahaha. Because Kevin steals shop supplies from my work.
Those discs are really that safe to use on the heads/manifolds huh? Do you go till its completely clean or just give it a good once over and call it good or what?
Assuming its OK for the cast iron block...
Posted: Tue Jun 10, 2014 10:39 pm
by uberkevin
Dude that thing is sweet! And I've used them on the Mani gasket before and work great.
I clean tell clean! Trying not to really press hard. It was also fast cuz there wasn't a problem. Hg came off easy and the surface wasn't anything bad, some fine sand paper would have got the job done..
Oh and it's rubber. Its not really scratching anything I don't believe.
Posted: Wed Jun 11, 2014 8:58 am
by draker
Clean, as in almost like back to a fresh machined look. Cause they are that good.
