Page 39 of 46
Posted: Tue Dec 29, 2015 11:50 am
by draker
Naw.. it's dry. Even on the parts that I sprayed way too much on.
Posted: Wed Dec 30, 2015 4:23 am
What kind did you use?
I'm probably going to do mine again. I love doing stuff twice. :aykm:
Posted: Wed Dec 30, 2015 7:15 am
Looking good Craig
Posted: Wed Dec 30, 2015 7:16 am
Taterhead » Wed Dec 30, 2015 4:23 am wrote:What kind did you use?
If at first you dont succeed try and try again
Posted: Sat Jan 02, 2016 12:47 pm
by draker
Taterhead » Wed Dec 30, 2015 5:23 am wrote:What kind did you use?
Posted: Mon Jan 04, 2016 11:33 am
Huh. Same VHT I used. Maybe I'm doing it wrong. Wouldn't be the first time.
Posted: Mon Jan 04, 2016 12:44 pm
by draker
That is strange .. ??
Posted: Mon Feb 01, 2016 4:40 pm
by draker
Posted: Mon Feb 01, 2016 9:50 pm
How's that cabinet working out for you?
There is a parts washer at my work I am going to start using :D
Posted: Tue Feb 02, 2016 8:33 am
by draker
izzo » Mon Feb 01, 2016 10:50 pm wrote:How's that cabinet working out for you?
After modding it, it works great. It could use better lighting.. which I'll install some day. And I need to get a better dust collector.
An oil pan is about the biggest thing I could reasonably blast. Could go bigger but it's pretty cramped in there with the hoses. Either way, I'm happy with the results and the cabinet is dirt cheap.
Posted: Mon Feb 08, 2016 4:30 pm
by draker
Posted: Sat Feb 13, 2016 11:11 pm
by draker
Posted: Sat Feb 13, 2016 11:14 pm
by draker
After I bead blasted the oil pan there was media in the pan.. event though I covered it some sand was still in there. I scrubbed and scrubbed... still dirty. So mixed some degreaser and water and heated it up. Then let is sit in the pan to work loose the grease and grime... and sand. Well... it started to strip the paint.
What a pain in the ass. It was all over in the pan... so naturally it ALL had to go. I had to do this about 3 more times to remove all the paint so it would not contaminate the oil later on...
Results:
Posted: Sat Feb 13, 2016 11:41 pm
Ive always heard that blasting media gets everywhere.
Posted: Sun Feb 14, 2016 12:01 am
by draker
Laecaon » Sun Feb 14, 2016 12:41 am wrote:Ive always heard that blasting media gets everywhere.
It definitely does! I had it sealed up with duct tape.. Still got in there.
Posted: Sun Feb 14, 2016 9:00 pm
by draker
Small update.. cleaned all the bolts and mounted the pan. I sand blasted a few bits.. not pictured. Will be mounted soon.
I put a bunch of work into this front cover and found a stripped oil pan hole. I got it for free so no complaints. Looks like I gotta buy a helicoil kit and get busy. It would probably be fine without it.. but I don't want oil leaking anywhere on this thing.
Posted: Sun Feb 14, 2016 9:21 pm
Can't you just use a longer 10mm bolt, they usually are not stripped the hole length of the hole.
Posted: Sun Feb 14, 2016 10:41 pm
by draker
wayno » Sun Feb 14, 2016 10:21 pm wrote:Can't you just use a longer 10mm bolt, they usually are not stripped the hole length of the hole.
That's the first thing I tried. No dice.
Posted: Sun Feb 14, 2016 10:46 pm
Well it's a lot easier to drill it, and thread it for the helicoil when it's on a engine stand.
It's even easier when you have someone else do it, but that is not as cheap. :lol:
Posted: Mon Feb 15, 2016 10:53 am
by draker
wayno » Sun Feb 14, 2016 11:46 pm wrote:Well it's a lot easier to drill it, and thread it for the helicoil when it's on a engine stand.
The good news is, it's just a M6x1 bolt. I'll trust a helicoil in this application. Time-sert was about double the price.. I figured that was a little overkill for the application.
Bad news is, the pan is sealed.. so I hope I can drill the pan hole just a little bigger and get the coil installed. Otherwise... fucking pan had to come off. We'll see when I get the kit.
