Page 5 of 19
Posted: Sun Jun 19, 2016 2:16 pm
by Indy510
Yeah .. I would never drive on 5" blocks and I want to modify the rear shackle mount someday
I just used the 2" blocks on top of 3" blocks to figure out how much of the driveshaft tunnel to cut, because without a fuel tank it was already an inch higher and the extra inch is just for clearance:
Posted: Sun Jun 19, 2016 2:20 pm
by Indy510
Posted: Sun Jun 19, 2016 2:25 pm
by Indy510
I had this 4x6 sheet of 18 gauge sheet metal, that I got a few years ago for the Rusty Ruby failure:
I recommend using two workbenches when trying to cut such a big sheet of metal, with a jigsaw:
Posted: Sun Jun 19, 2016 2:40 pm
by Indy510
Almost clean:
Posted: Sun Jun 19, 2016 2:44 pm
by Indy510
Drew lines, to match the stock tunnel, which included a slight widening of the tunnel towards the back. I used a piece of 2-1/4" DOM tube, and a piece of angle iron, in the vise to match the stock curve:
Posted: Sun Jun 19, 2016 2:45 pm
by Indy510
Posted: Sun Jun 19, 2016 4:20 pm
That's great work, Indy.
Posted: Sun Jun 19, 2016 6:43 pm
It really is! Nice job so far.
Posted: Tue Jun 21, 2016 7:16 am
by K_trip
Indy510 wrote:I want the backseat to still fit, so I made a bent 1x2 piece to reinforce the hacked out area:
That's the difference between a well executed mod and a hack job, planning the finish up front.
Lov'n it
Posted: Thu Jul 07, 2016 8:33 pm
Annnnnnn thennnnnnn
Posted: Fri Jul 08, 2016 10:38 am
by Indy510
Posted: Fri Jul 08, 2016 10:39 am
by Indy510
Made some fish plates ... and coated the back with weld-thru primer ... but it helps to scrape it off for 1/4" around where the welds will go
Posted: Fri Jul 08, 2016 10:40 am
by Indy510
Posted: Fri Jul 08, 2016 10:43 am
by Indy510
Ended up starting over with the new tunnel pieces .... the first piece didn't fit good enough:
Posted: Fri Jul 08, 2016 10:55 am
by Indy510
Made a list:
Posted: Fri Jul 08, 2016 10:57 am
by Indy510
Wanted it to look level:
by Indy510
Posted: Fri Jul 08, 2016 11:24 am
by Indy510
And done:
Posted: Fri Jul 08, 2016 12:12 pm
Holy shit dude!!! That's wayyy better... Hell that looks damn near factory. You've come a long ways with your skill vs the red 510.
Posted: Fri Jul 08, 2016 4:31 pm
Looks good.
