the red banner
Re: the red banner
Now I have makunis.... ill use the makunis on the redbanner.
Re: the red banner
Those would look good on my truck
Re: the red banner
Save money.
I got 2 rebuilt carbs, linkage set, and isolators , stacks, filters, throttle cable, for 600ish shipped.
After what I have into a pile of solex carbs.it felt like a bargin
Re: the red banner
Just when I got started I got called away, but painted up my z20e block.
Was pretty clean actualy.
Wish they all where this easy
Had alot of paint pen marks on it, and it was painted blue with the timing cover on, wounder how many cars this has been in.
Its a z20e, wich means flat top pistons and 6 inch rods.
Got the front cover and pan off before I had to go.
More when I get back.
Re: the red banner
Yeah. But the z20e is basicly a l20b, the cranks the same, the block is the same, the rods are longer (6inch) and the pistons areflat tops. The displacment will be the same. The stroke will be the same. so im basicly building an l20b, you could call it an lz. Ill probably just call it a long rod 20b myself.
- Has thanked: 671 times
- Been thanked: 245 times
Re: the red banner
Long live leopard long rod 20b !!
Re: the red banner
long rods make for good torque I'm told. Should be a fun quick moatar omnomonomonomskeet
PS, why is thar pink on that motor stand
Re: the red banner
Painted my sister in laws motor on it.....
Reached a problematic point her. All my books claimed that a z20e piston sits .07 below deck and has 3.44 cc valve releifes... well thats not correct. It sits .007 below deck and has 1cc of valve relief.... wich pushed compression up tp 10.7... that wont work at all. I may be screwed here. How could 3 catologs be off on the cc numbers and all show the same thing... fuck.
I dont think I can remove the cc needed to get back to 10:1 ish. Fuck.
Re: the red banner
Jeez dude, for pink that motor sure looks nice.
Idk about your CC problem man
Re: the red banner
With which head are you getting 10.7?
I did the math a while age on the z20 from the A10 with a u67 and it was like 9.9ish.
Re: the red banner
9.9 is way too high on an open chamber. Im at 9.35 with a U67 and ping with anything except Chevron or 76 Premium (Yes shell pings in my car). A cam would help. I want to say Jessi's motor is at 10.8, and well you know about that... Bigger cam!
Re: the red banner
Weird, I'm at 9.7 and it'll run on anything and never pings.
...Oh yeah, maybe it's the knock sensor
. EFI is flippin sweet. It runs fine no matter what -- just runs better on higher octane.
Re: the red banner
Yeah. Exept its not a a10 z20. Its a 200sx z20e, I have longer rods and flat top pistons.flatcat19 wrote:With which head are you getting 10.7?
Wich on paper with a closed chamber should be 10.1:1 but the deck height and cc of the valve releifs is incorrect in most litariture.
If I ran a open chamber head I would have 10.5:1 compression.... way to much for an open chamber.
Not that 10.9:1 isnt too much for my w53.....
I could do a couple things. Thicker head gasket, I have a felpro so the crush height is 1.2, a nismo gasket is 1.5. Or I could have a 2.0 gasket made. Maybe run a 87mm bore gasket. Could get a couple points...
What im going to do is is clean up the combustion chamber to match my head gasket, and brow the block. Deshroud the valves and the cc them again. Hoping for 2cc or more. 2cc would put me at 10.44:1, in the range of doable, with a close chamber.
And 10.01:1 with an open chamber, probably not doable.
Re: the red banner
Browing he block big valves and a cam you will be fine you might have to recurv the distributor though
kittens and bj's
Re: the red banner
Im still.looking for a local to recurn my dizzy. Called a couple folks and well... nothing so far.
Ive done some of the math, and I think I want around 30 degrees advance, and it to be all in at around 2k.or less.
Anybody recomend someone for recurving my dizzy?
Re: the red banner
My buddy nick came and chexked out my head. He is an experianced machinist, cool dude, people come along way to get there chevy heads built by him, and thevtec kids with there hybrid motors too.
He has built all my brothers race heads and he is sure he can get me squared away.
I marked where I was going to grind out, and he agreed I had it laid out but insisted I let him have the grinder lol
Should have it at the machinist friday for the lightest suface possible. Its at -.007 cee's can take .003 off so that would be -.010
But im using a felpro hg, so its .3mm shorter than stock wich is .0118,
So thats -.0218 total right? Cause I need shims at .015. I think.
Im just not sure wich of these numbers are metric and wich are standard lololol
