Page 1 of 1
KA24 rebuild?
Posted: Sat Oct 04, 2014 3:20 pm
by Farmer Joe
welp, the time is upon us to try and take this KA apart soon.
ive got a 93 d21 KA single cam in the truck.
guess my first question is the main and rod bearings between all the KA variants. are they the same or are there specific sets for certain KAs?
secondly, can i use single cam s13 rods with the truck crank?
overall goal is to use s13 pistons to bump the compression up in the truck engine.
id like to have that compression bump to go with the s13 cam i have.
thanks!
Re: KA24 rebuild?
Posted: Sat Oct 04, 2014 6:51 pm
by Farmer Joe
welp, nevermind..
found what i was looking for..
http://www.ka-t.org/forums/viewtopic.ph ... gine+specs
truck KAs have bigger main and rod bearings than the s13 counterpart.
so it looks like im stuck with 8.6:1 compression..
i guess another question would be, can 240sx pistons be used on truck rods?
Re: KA24 rebuild?
Posted: Sat Oct 04, 2014 10:38 pm
I think so... Just would have to have the small end modified for a floating pin...
Re: KA24 rebuild?
Posted: Sun Oct 05, 2014 1:07 pm
Are you looking for a custom combo or just need to freshen up a tired engine?
Re: KA24 rebuild?
Posted: Mon Oct 06, 2014 12:16 pm
by Farmer Joe
mainly a rebuild on a tired engine..
seeing if i might be able to do a cheap or free compression upgrade, but im not too worried about it.
Re: KA24 rebuild?
Posted: Tue Apr 26, 2016 3:45 pm
by KamikazeGarage
One thing to keep in mind, is Nissans bearing grading system. The block should have numbers 1-4 next to the mains, and respectively on the crank. Sometimes you can get by with STD bearings, if you can take material off with a micropolish
Re: KA24 rebuild?
Posted: Fri Apr 29, 2016 10:15 am
by Justinberni
KamikazeGarage wrote:One thing to keep in mind, is Nissans bearing grading system. The block should have numbers 1-4 next to the mains, and respectively on the crank. Sometimes you can get by with STD bearings, if you can take material off with a micropolish
your a couple years late man.. haha
Re: KA24 rebuild?
Posted: Sun Jun 05, 2016 12:08 pm
by KamikazeGarage
Shit, well at least itll be there for future searches lol.
Re: KA24 rebuild?
Posted: Sun Jun 05, 2016 12:55 pm
I got away with STD bearings. Either my CA had no miles, or the cranks just dont wear.
