Need b210 parts
Posted: Sun Jan 03, 2016 10:45 pm
In need of a short water pump pulley and fan that goes with the pulley for an a series motor. There's a long snout one and a short one. I have the long one so the belt doesn't line up.
I need a b210 down pipe. It's the three hole version from the manifold down.
I could use a headlight switch.
I need a b210 clam she'll. At least the bottom piece. I also need the ignition switch. The po removed the ignition switch and used some wires with spades to hook up toggle switches.
Need a glove box door.
