1974 B210
Posted: Wed Feb 01, 2017 11:04 pm
Well.
Am getting out from under all the cars and projects I have.... Everythings gotta go
1974 B210, A14, 4 speed.
New...
Clutch
Front brake pads, bearings, rubber brake lines
Rotors turned
Rear brake shoes replaced, along with wheel cylinders and rear brake rubber line
Brand new tires with only a few hundred miles on them
Mesh rims. I think appliance? I'll have to look
Some hoses are new
Weber with new adapter kit and gaskets
Motor has been re-gasketed. Pretty clean
EGR Cock off plate
Electronic Ignition
What it does.. Starts, runs, drives.
What it needs. headlight switch, IGN switch, a few more hoses, brakes bled again, seats installed. Hoses for the heater core. It may need a few more items, but this will get you driving around. Fresh oil & filter. Needs seats installed, too. Have a few sets to choose from
It has rust in the spare tire area. It may have a hole or two, but it def needs sanded and por15
Passenger side floor board has a rectangle say 4 inches wide and a foot long maybe more/less that is soft and needing replaced
I'm sure there is more New stuff, and stuff it could use I'm forgetting.
Price IS negotiable. May take less if I keep the wheels(including tires) and weber.
Clean WA title
New...
Clutch
Rotors turned
Some hoses are new
EGR Cock off plate
Electronic Ignition
Clean WA title
