Page 1 of 2
78 KC DD
Posted: Fri Jul 12, 2013 11:49 am
by Eagle_Adam
my brother has been rocking a 720 4x4 as his DD for the last year or so, but he got a new job that tripples his commute easily but the $ is worth it so i went on the hunt for a CHEAP DD for him.......
this is what i ended up with:
1978 620 King Cab!!
the ad popped up on CL and i was there 45 min later, no pics in the ad but it had all the right tell tell signs
The truck is a good 10ft truck!
Re: 78 KC DD
Posted: Fri Jul 12, 2013 11:52 am
by Eagle_Adam
ad said it was a runner, but when i got there is wasnt even close. Battery was dead, gas tank was empty, keys were MIA, and it had 2 flat tires......
Not a good start -.-
Soooo..... Off i went to tinker town!
Truck came with an interesting bench seat
Interior is a 7/10
Re: 78 KC DD
Posted: Fri Jul 12, 2013 11:53 am
by Eagle_Adam
but after tossing on a spare tie, putting gas in the tank and in the carb, chased down a few electrical gremlins, putting my optima yellow top in, and changed out a few fuses.....
Vid:
I had a running 620!
Re: 78 KC DD
Posted: Fri Jul 12, 2013 11:54 am
by Eagle_Adam
truck has:
4speed
L20 bottom end
round port W58
header
weber 32/36
so now i need to do a once over and make a list of fixes that are needed before i can hand it off to my brother
So far i need to:
replace the temp sender, the PO tried to put in an aftermarket gauge setup and never finished
replace the oil pressure sending unit - same sead the PO put in an aftermarket gauge but i dont like the idea of an oil line going into the cab
new battery
new rims and tires
check the breaks
check all fluids
Im going back today to put new tires on it and drive it home!
Re: 78 KC DD
Posted: Fri Jul 12, 2013 7:35 pm
by Str8_69
Looks like a good score man, hope you got into it right!!
Re: 78 KC DD
Posted: Sat Jul 13, 2013 2:11 am
by Eagle_Adam
Got 4 usable tires on, and made it to a gas station for air, a clean windshield, and it's first tank of gas!
Then got her home and started a once over and tune up.
Finished around midnight but got a lot done
Re: 78 KC DD
Posted: Sat Jul 13, 2013 7:30 pm
by Devious620
Another Fucking Tach!!! Lol
Re: 78 KC DD
Posted: Sun Jul 14, 2013 3:26 pm
by Eagle_Adam
Yes but it's aftermarket
Re: 78 KC DD
Posted: Sun Jul 14, 2013 3:35 pm
by Eagle_Adam
Got her home and started the good ol once over!
I promised myself no matter what I'm not modifying this truck in any way shape or form. No lowing, no motor improvements unless forced, all function
Popped the thermostat open to replace it and found there wasn't one...
Replaced:
Plugs
Wires
Cap n rotor
Thermostat
Valve cover gasket
Oil change
Removed the old oil pressure unit and temp sender, changed em back to stock cus they weren't working
Re: 78 KC DD
Posted: Sun Jul 14, 2013 3:45 pm
by Eagle_Adam
Re: 78 KC DD
Posted: Sun Jul 14, 2013 3:51 pm
by Eagle_Adam
Last night was frustrating, snapped a bolt it the dizzy adjustment plate....
But an easy tool care of it
So we adjusted the timing, replaced the fuel filter and hoses, and threw in a spare center console I had
Re: 78 KC DD
Posted: Wed Jul 17, 2013 12:46 pm
by Eagle_Adam
need to find a drivers side window regulator and some exhaust and this one should be road worthy
Re: 78 KC DD
Posted: Wed Jul 17, 2013 3:18 pm
nice man real nice. cleans up well eh?
It needs some wheels
Re: 78 KC DD
Posted: Wed Jul 17, 2013 3:19 pm
by Eagle_Adam
yep, cleaned up better than i thought it would.
Its gunna get the rims from my first 620
Re: 78 KC DD
Posted: Wed Jul 17, 2013 6:28 pm
Eagle_Adam wrote:need to find a drivers side window regulator and some exhaust and this one should be road worthy
Why does everyone forget I have an entire 620 I don't want?
Anything. Everything. Yours.
Come get it.
Re: 78 KC DD
Posted: Thu Jul 18, 2013 8:42 am
by Eagle_Adam
is there a good/decent exhaust on it?
willing to pull and ship the drivers side window regulator?
got keys for the door locks? matching ignition?
short box? if so what condition?
Re: 78 KC DD
Posted: Thu Jul 18, 2013 11:41 am
Eagle_Adam wrote:is there a good/decent exhaust on it?
Exhaust should be decent. I took the manifold for my own stash-but will part with it, IF YOU NEED IT, because it's you.
If you need the regulator, I will. Was trying to keep the door as a single unit. But for you...
I think I have the door lock keys and ignition. I will look when I get home.
Short box is in great shape.
I do have a brand new Nissan ignition with 2 new keys on eBay right now.
It's a contributing member to my getFlatADFat fund.
http://www.ebay.com/itm/300934386506?ss ... 1555.l2649
Shameless plug? Sure.
But I need a 210!
Re: 78 KC DD
Posted: Thu Jul 18, 2013 11:47 am
by Eagle_Adam
pics of the exhaust please, dont need the manifold
price on regulator plse
im good on the locks for now just curious in case the ones i have dont work
Re: 78 KC DD
Posted: Thu Jul 18, 2013 11:57 am
Eagle_Adam wrote:pics of the exhaust please, dont need the manifold
For you-they're yours.
Just don't know about shipping.
GreaseMonkey was supposed to coming to haul this thing off.
Haven't heard anything from him. PM'd him Tuesday.
Re: 78 KC DD
Posted: Thu Jul 18, 2013 12:19 pm
by Eagle_Adam
forgot your in the tri cities...
probably gunna have to pass on the exhaust unless greasemonkey can grab it
please pull the regulator and ill pay shipping when you figure it out
