got the black paint on
got the crank gear replaced
chased all the threads everywhere on the block - timing cover, oil pan, timing parts, and head bolts
and this is why
timing chain guides are on
started stripping the floors for POR 15
gunna have to weld in floors on the passenger side too :/
and i scored a $20 shelf for parts!
more cleaning and rust removal
found some holes in the passenger side too so i picked up some fiber glass to reinforce it
POR 15 and fiber glass is done! and ROCK HARD!!!
also treated a few spots in the engine back with rust converter and primer
not a perfect color match or really even close but it will work for now
started cleaning up parts
Then it was onto the motor assembly
timing parts are on
prepped the block surface and off we go
Heads on
thought this was a cool pic that shows how a timing block works
Got the front cover on, new KA oil pump in and clocked, then the oil pan on, and then i snapped a bolt installing the water pump.....
so i grabbed my eazy out kit and removed the stud only to find out the hole is cross threaded and i need a new timing cover
picked up an L20 motor from RedBanner monday, and tore it down last night to get the timing cover
Now i gotta clean up the new timing cover and tear down the motor from my dads truck to install the timing cover
the old fly wheel needed some help so i tossed out a feeler and dislexic dime answered with a new one :
Old
Floors are done, seat is in, and new black retractable seatbelts are in
Skib, jassifrass, nismo dr and I dropped in the motor and trans on sunday
Now to plumb and wire everything
headlights and grill are in!
heater core is cleaned up with new foam added
heater core is back in
door panels are going back on
Motor is about buttoned up
Got the trans back in! i was just tired and doing something wrong cus it worked just like i thought it should have the 2nd time around.
So with that out of the way i got back into the swing of things
Drum breaks are all adjusted and ready to go
trans is in
interior is going back together
picked up a head unit and speaker wire so i can install the gauge bezel
valves are checked and adjusted
painted under the cowl
still to do before it can be a DD:
install drive line
finish installing the interior
figure out the fan issue - the pulled from a 280 zx was what i was told was right but it isnt .
install cowl
install hood
exhaust welding
and drive this SOB!!!
____________________________________________________________________________________________________________
ok, soooooo its been a long time since iworked on this project. Since my car accident i havent been able to do nearly as much wrenching as i used to but im getting back into the swing of things now!!!
Lest weekend i got the new stereo wired in and ready to go
center console is in
old water pump was taken out in prep for on with a fan clutch
Things to do:
find a replacement hard line for coolant that goes around the front of the motor
install the new water pump
install the one piece drive line from my old truck
install the speakers
the whole gauge cluster is still out - so install it as well
rewire a few things
and get this one on the road!!!
got the new one piece driveline in!
Got the water pump in!
I just need to figure out this last coolant hardline and the gauges then its off to the exhaust shop and on to a DD status
FINALLY!!!!
