Page 1 of 1
WTB a STOCK IR alt for a 78 620
Posted: Wed Aug 07, 2013 9:48 am
by Eagle_Adam
dont have time to dot he IR swap right now, i have bigger problems...
If you have a drop n go alt for a 620 id like to pick it up, looking for cheap
EDIT: just need a stock IR alt now
Re: WTB alt for a 78 620
Posted: Wed Aug 07, 2013 12:35 pm
adam. the IR alt swap literally takes less than a minute... Its two lengths of 2" wire and four spade connectors (unless you have a round plug, then its two butt connectors) Everything else is plug and play.... 720 alt is 60amp normally and drops right in....
I have a Z IR alt in my parts stash.
Posted: Wed Aug 07, 2013 12:36 pm
Tell you what, man. If you find an IR alternator, I will be going to blue lake and will do it for you even..
BTW, 78 and on had IR alternators. unless your's was a funky inbetweener
Posted: Wed Aug 07, 2013 2:16 pm
by Eagle_Adam
wait.......
WTF
78 is an IR alt?
Posted: Wed Aug 07, 2013 2:18 pm
by Eagle_Adam
holy shit, ur right....
Posted: Wed Aug 07, 2013 10:58 pm
That was easy.
Whew!
Posted: Thu Aug 08, 2013 8:20 am
by Eagle_Adam
learn something new every day!!!
Soooooo..... now i need a stock IR alt for 78/79
Posted: Thu Aug 08, 2013 7:28 pm
Eagle_Adam wrote:learn something new every day!!!
Z or KA will bolt on. Need different belt.
Ask me how I know.
Re: WTB a STOCK IR alt for a 78 620
Posted: Thu Aug 08, 2013 7:56 pm
by datsunmike
Only the 620 alt fits properly. Car or 720 alternators are larger diameter and sit very close to the idler arm just below it. You need a shorter belt and a 280z/zx lower rad inlet to move the rad hose up and to the rear out of the way. I also used a 720 block mount that lifts the alt. slightly. Still had to put the belt on the pulley first then put the mounting bolts in.
Posted: Thu Aug 08, 2013 9:28 pm
the 720 alt is smaller, or so I thought.... I threw an 85 ST alt in my B I can measure my ST alt VS a older alt I have laying aruond and see if there's a huge different.
I was told before the 720 ones are smaller so they are a drop in affair. the 83 and 84 720 alts were also used in the early sentra, 310s, and i think one of the hl510s
Posted: Thu Aug 08, 2013 9:35 pm
The alt I put on the blue LZ 521 I had was from a KA.
Bolted in. It seemed like there was no movement.
As soon as I got a belt on it, there was more than enough room to tighten and remove the belt without issue.
Granted, I'm sure it fit better going from Z to KA.
Never tried to fit any different alt on to an L.
Posted: Thu Aug 08, 2013 9:46 pm
I had an alt I switched from my 720 to my 510 back in the day, worked fine. Pretty sure this one is smaller... 620s are a little different, but i'm pretty sure the 720 alts fit.
Adam... the alt in the red 720 KC 4x4 is brand new, go rape it and test fit it.
Posted: Fri Aug 09, 2013 8:40 am
by Eagle_Adam
the 720 isnt at my house....
Posted: Fri Aug 09, 2013 6:10 pm
by Eagle_Adam
Taken care of - this can be locked
Posted: Fri Aug 09, 2013 7:34 pm
by datsunmike
izzo wrote:I had an alt I switched from my 720 to my 510 back in the day, worked fine. Pretty sure this one is smaller... 620s are a little different, but i'm pretty sure the 720 alts fit.
They will be similar size, plus there is nothing near it on the cars. The 620 has a frame rail with an idler arm poking up almost into the bottom of the alternator. I made one fit but it does not replace or drop into the place where the stock 35amp one was.
Posted: Sat Aug 10, 2013 11:33 am
Bummer man. Thought for sure it fit
I think he shagged one at the PNP.
Posted: Sat Aug 10, 2013 11:42 am
He did. A 720 one, looks fairly small, definitely smaller than ZX
Posted: Sat Aug 10, 2013 5:14 pm
And no go without zx inlet and shorter belt.
