Instrument Panel/dash Cluster Voltage Regulator (Fuel/temp)
Posted: Sun Oct 06, 2013 9:36 pm
Sorry no longer available! I'll update if I do another run of these.
Instrument panel voltage regulator. Will fit 68-69 510. Will also fit 311/411/520/521.
Sold state part that replaces the mechanical voltage regulator for the fuel and temp gauges. So if you have a roadster or early pickup or 510 with flaky or misreading temp and fuel gauges this may be a part to replace.
Direct plug in. Red wire is 12V+ in. White wire is 9V+ out to gauges. Ring terminal is 12V- (ground) and screws to the back of the gauge cluster.
$15 shipped in the US. Paypal address is: dguy210(at)gmail(dot)com
The original part looks like a small metal box on the back of the cluster (68 510).
From the side you can see the male spade connectors and ring terminal (right of photo).
How the replacement part plugs in. This can be replaced on the 510 without pulling the dash or cluster. I don't know for the roadster or pickups if this is also true but probably.
On the left is the old part on the right is the new one plugged in. Leads are left a bit long to make it easier to plug in to the dash cluster without pulling the cluster.
Note: this is also posted on Ratsun, but due to the dumbass way the classifieds work no one ever sees it.
Email is dguy210(at)gmail(dot)com
