Page 1 of 1
aluminum rad for a KA24DE swapped 78 620.......
Posted: Mon Nov 18, 2013 2:06 pm
by Eagle_Adam
ive searched and searched and havnt found "enough" answers
i dont really want to run the stock rad in my 620 when my KA swap is done, so im curious if anyone can point me towards aluminum rads that "fits" (bolt in not needed, but would be a bonus) and im also after an electric fan set up but thats another story
Re: aluminum rad for a KA24DE swapped 78 620.......
Posted: Mon Nov 18, 2013 3:44 pm
by peanutbuttercups
I want a Ron Davis radiator I know they will fit510
Posted: Mon Nov 18, 2013 3:48 pm
by Eagle_Adam
ya.... there's lots of options out there and documented but the 620's not so much
Posted: Mon Nov 18, 2013 4:29 pm
http://www.griffinrad.com/ordering.php?tid=39
There was someone that put a SR in a 620,they used a Griffin rad,I do remember it looking like a real easy install if that helps
Posted: Mon Nov 18, 2013 8:16 pm
A lot of the 620 rads listed on eBay also note fitting a 510.
Is there a size difference at all?
I have seen postings for KA swapped 510 radiators on eBay as well.
Inlet/outlets on the right/correct sides.
Posted: Mon Nov 18, 2013 8:46 pm
They are not the same. Don't trust eBay.
Posted: Mon Nov 18, 2013 10:43 pm
by squatches
Laecaon wrote:They are not the same. Don't trust eBay.
^ this the truck radiator is taller by about 2 or so inches, the aluminum radiator i picked up for my 510 was made by griffin it was for some sort of volkswagen and fits the 510 well but would be short in the 620. look at one for a vr6 engine from volkswagens i plan on putting this in my 620 when i swap it, it has the inlet and outlet on the same side. you have to put a T fitting in the hose tho since it doesn't have a cap on the radiator.
http://www.redline360.com/mishimoto-rad ... RAD-GLF-94
Posted: Tue Nov 19, 2013 9:11 am
by Eagle_Adam
squatches wrote:Laecaon wrote:They are not the same. Don't trust eBay.
Overall Size
29.92" x 15.35" x 2.07"
its too big for a 620.....
i really just need to drop my KA into my truck so i know how much room i really have :/
Posted: Thu Nov 21, 2013 11:47 am
by Eagle_Adam
problem solved a 1980 RX7 rad looks like it will fit - i ordered one so i guess ill find out
Posted: Sun Dec 01, 2013 8:48 pm
by Jester
I put an aluminum radiator from a Volvo 240DL in my last truck. Fit was nice with no cutting of the core support. Easy enough to make mounts for it too. As soon as Datsunmike finds my old thread at Ratsun, I'll post some pics and more details for you.
Jes
Posted: Sun Dec 01, 2013 8:51 pm
by draker
It's sitting in the pile of hidden threads. Something about needle and a haystack?
Posted: Mon Dec 02, 2013 1:32 pm
by Eagle_Adam
it will be a week or two before i can test fit it with a motor in but here she is
Posted: Mon Dec 02, 2013 2:23 pm
by draker
Looks really nice!
Posted: Mon Dec 02, 2013 2:35 pm
by Eagle_Adam
now to test fit...
Posted: Mon Dec 02, 2013 4:56 pm
I need to check this rad out. The same company makes a shorty RX7 radiator, which is shorter but wider than the one you got, still 3 row and everything though. I think it might be perfect for the 510... because I dont like the current 510 options...
Posted: Mon Dec 02, 2013 7:56 pm
Who is the maker?
Posted: Fri Dec 06, 2013 9:15 pm
by B-keeper
flatcat19 wrote:ho is the maker?
GOD
Posted: Fri Dec 06, 2013 10:04 pm
B-keeper wrote:flatcat19 wrote:ho is the maker?
GOD
Is he related to that Darwin guy?
Posted: Sat Dec 07, 2013 2:11 am
by Eagle_Adam
http://bit.ly/1cgwKIi
Here's the eBay link
