Page 1 of 1
Dogleg Nutrual and Reverse switches
Posted: Thu Mar 27, 2014 10:19 am
by draker
If you have these in good shape with the leads, I need them. Not looking to spend a lot.
I might end up just soldering leads back on the switches I have if I can find the connectors.
Let me know what you've got.
Thanks,
Craig
Re: Dogleg Nutrual and Reverse switches
Posted: Thu Mar 27, 2014 9:44 pm
by Gray
draker wrote:If you have these in good shape with the leads, I need them. Not looking to spend a lot.
Thanks,
Craig
I'm not sure on the neutral switch but I think the reverse switch was pretty much the same on all the RWD stuff so JY maybe. They're about ~$10-20 off ebay.
Posted: Thu Mar 27, 2014 9:46 pm
by draker
I do have the reverse switch from my 4 speed. Not sure if it's worth my time to even deal with the NSS since the stock wiring doesn't support it. It should be easy to adapt though.
I figured if someone had them handy.. I'd snag em up.
Posted: Thu Mar 27, 2014 11:11 pm
Just delete the NSS. That is how I run my car. And it does support it... kinda... You just have to modify the stock inhibitor wiring. Take the two Black/Yellow wires at the relay and run them to the switch... I think that will make it work, or it will be backwards. I would sooner just wire it to a clutch pedal switch.
But yea, just be mindful of when you bump the starter. I probably miss bumped like 4 times, and then I caught on.
Posted: Fri Mar 28, 2014 3:44 pm
by draker
Yeah, I may just leave it as is. If I find it's an issue.. I'll wire it.
Posted: Fri Mar 28, 2014 5:18 pm
Well you will have to connect the black yellow wires to even start it.
Posted: Fri Mar 28, 2014 7:06 pm
by draker
This isn't an auto --> manual swap. Just 4sp to 5sp.
Posted: Fri Mar 28, 2014 8:45 pm
Oh...
