The Killer B
Jamee
Title: Fluffer
Cars: 1977 Datsun B210
Re: The Killer B
#61
Post by Jamee » Mon Jul 22, 2013 10:20 am
lovin it all! thats one sexy b you got. :D
:boobs:
Has thanked: 3 times
Re: The Killer B
#62
Post by flatcat19 » Mon Jul 22, 2013 10:44 am
Damn straight!!!!
:fyea:
Re: The Killer B
#63
Post by izzo » Mon Jul 22, 2013 9:50 pm
finished sanding the other front rim. the back ones don't look to bad.
Aired up the front two, need to finish the rear two... Will do that tomorrow morning as I am putting them on the B :D
Has thanked: 2 times
Been thanked: 5 times
Re: The Killer B
#64
Post by 510freak » Mon Jul 22, 2013 10:00 pm
woohoo!
Cant wait to see the end result Tim
Re: The Killer B
#65
Post by izzo » Tue Jul 23, 2013 9:15 am
suspension hasn't settled in the front from swapping tires yet.. also found out my rear cylinder is leaking on the passenger side. I just bought two cylinders and replaced the driver side, this was on the list already. Guess it's happening sooner than later :D Ill order up some shoes and spring kit, might as well do it all now that its saturated in brake fluid.
Anyways, here she is. Again, the front hasn't dropped yet as I haven't drove it... Just aired up the tires and getting ready to take it for a spin after i double check the lug tightness
Re: The Killer B
#66
Post by RedBanner » Tue Jul 23, 2013 10:25 am
So how far did the front settle?
Re: The Killer B
#67
Post by izzo » Tue Jul 23, 2013 10:52 am
taking a pic meow brb
Re: The Killer B
#68
Post by izzo » Tue Jul 23, 2013 11:03 am
Re: The Killer B
#69
Post by BLUE » Tue Jul 23, 2013 4:44 pm
hory chit !!
:shock:
:twisted:
Those look GOOD !!! Izzo
Re: The Killer B
#70
Post by izzo » Tue Jul 23, 2013 4:46 pm
Thanks man!
They do look pretty badass... I'm getting some vibration when I drive. I double checked the lugs, they tight, shook the wheels, they on tight, air is correct PSI on all four, these are directional tires pointing in the right direction. I am thinking maybe they need balanced... I'm sure les schwab will rape me a bunch for balancing the wheels, mounting and dismounting... So just gonna rock them for now till i can find a spot to do it cheaper.
http://hpwizard.com/tire-calculator.html
165/55r14
Re: The Killer B
#71
Post by flatcat19 » Tue Jul 23, 2013 6:19 pm
Those wheels are a complete game changer.
Re: The Killer B
#72
Post by izzo » Tue Jul 23, 2013 7:41 pm
Oh yeah they are. Just gotta get the vibration thing figured out. Seems the worse of its around ten/fifteen up to forty or so. At around sixty its not as bad tho still there
Re: The Killer B
#73
Post by BLUE » Wed Jul 24, 2013 3:49 pm
You got this.
Does it "shimmy" through the steering wheel ?
Re: The Killer B
#74
Post by izzo » Wed Jul 24, 2013 3:57 pm
Negative. I got it checked out. three were out of balance, one has a slight ding in the lip. leaves me with a little vibration at about 40mph, but only a little one... so good to go.
Re: The Killer B
#75
Post by BLUE » Wed Jul 24, 2013 4:12 pm
izzo wrote:Negative. I got it checked out. three were out of balance, one has a slight ding in the lip. leaves me with a little vibration at about 40mph, but only a little one... so good to go.
THAT..is awesome news my friend ! ..
a little vibration never hurt no one 8-)
I have a bent spacer on the front passengers of my yellow z that cause #$%# sometimes with a shimmy :lol: ....
The (3) of the tires were bald as @[email protected]$ when I bought it ... it also had a flat-spot on the one that wasn't bald .. :lol:
lug-nuts weren't tightened down eveny (or at least close)
that was an interesting drive home + my stupidity = derp derp derp.
Re: The Killer B
#76
Post by izzo » Thu Jul 25, 2013 11:07 am
Re: The Killer B
#77
Post by RedBanner » Thu Jul 25, 2013 2:49 pm
When we getting like buttons?
Re: The Killer B
#78
Post by izzo » Thu Jul 25, 2013 2:56 pm
I cant figure out how to import it into this theme. Maybe jacob can
Re: The Killer B
#79
Post by izzo » Fri Jul 26, 2013 1:32 pm
Adjusted air feul mixtute since the air filter is gone. Replaced cylinders now just waiting for shoes and spring hardwarekit to sshow up and the rear brakes are complete and all new.
Re: The Killer B
#80
Post by 510freak » Fri Jul 26, 2013 1:54 pm
Your new wheels sure look purdy on the b Tim
