the mine now coupe.
Has thanked: 42 times
Been thanked: 14 times
Re: the mine now coupe.
#501
Post by DRIVEN » Tue Aug 05, 2014 5:11 pm
I had a car once that had a shitty tank vent. When it got low it would suck the bottom of the tank up and raise the float on the sending unit giving an incorrectly high gauge reading.
#502
Post by RedBanner » Thu Aug 14, 2014 4:35 pm
So, I got about 38 mpg, but my gage is a bit wack. It has to be something with the altenator or how I wired it in. Its the only thing that changed.
Everything else is working good. But im going to swao the oil filter because it seeps alittle, theres a drop danglin from it every time I look, but I never see it on the ground.
#503
Post by RedBanner » Sat Sep 06, 2014 10:27 am
Loaded 800# in the back of my 1200, still does just fine, up hill, down hill, passing, no problems.
Fucking awsome.
#504
Post by DRIVEN » Sat Sep 06, 2014 11:09 am
Grainy pic looks like it coulda been taken in the '70s.
#505
Post by draker » Mon Sep 22, 2014 11:54 am
#506
Post by RedBanner » Sat Oct 11, 2014 11:09 pm
There where 4 different greens listed for the 1200s!.
So today i was driving up the winchester grade. 7 miles of 7percent. And a deer jumped out infront of the dodge truck doing 75 4 car links infront of me. The truck never hit its breaks so for a second i thought "must have missed it" then it came rolling out from underneith the truck. The front suspention on my 1200 cleared what was left fairly well. Little bump. But the rear axle spread the carcuss out all over my lane.... it was pretty freakin gross.
Ive been thinking about getting a much lower geared rearend and lifting my sunny to a rally stance all day.
#507
Post by RedBanner » Sat Oct 11, 2014 11:10 pm
Also rolled over 43000 on the odom today. Time for an oil change.
#508
Post by RedBanner » Mon Nov 10, 2014 3:59 pm
#509
Post by RedBanner » Mon Nov 10, 2014 4:09 pm
#510
Post by izzo » Tue Nov 11, 2014 6:04 pm
I like the angle of this. It looks like the camera is seeing the car look down the river. Teehee!
#511
Post by RedBanner » Thu Feb 12, 2015 11:34 pm
Had to rip may master and calipers out and rebuild them after work, brakes stuck hard on during a drive.
Spent four hours rebuilding them. Took one picture. Lol.
#512
Post by RedBanner » Thu Feb 12, 2015 11:37 pm
I spent 3 hours trying to avoid rebuilding them yesterday, wich made it much worse, figures.
Has thanked: 4 times
Been thanked: 17 times
#513
Post by Laecaon » Fri Feb 13, 2015 1:34 am
Whoa a Banner sighting!
brake work is seldom "fun". Something about that brake dust...
#514
Post by RedBanner » Fri Feb 13, 2015 1:43 am
Should have heard it screaming on the way home today. All i could do was crack the zerk and force the piston in alittle and usethe ebrake. Worked for 2 mile increments for my 30 mile trip, the calipers should really be replaced but im broke as shit, have to work tomarow and getting to work is #1
#515
Post by RedBanner » Fri Feb 13, 2015 7:01 pm
Found one other pic. Breaks work great now.
datsunfreak
#516
Post by datsunfreak » Tue Apr 14, 2015 8:29 pm
DRIVEN » Sat Sep 06, 2014 2:09 pm wrote:The hair, beard, shoes, car, building, and grainy pic looks like it coulda been taken in the '70s.
Fixed. :rofl:
Stuck in the 70s...
#517
Post by RedBanner » Tue Aug 18, 2015 10:01 pm
well loosing my rear diff, I knew it wouldn't hold up long,
#518
Post by Ni10 » Wed Aug 19, 2015 6:06 am
I've got a rear end here and not sure what it's for. Call me with a measurement and I'll check to see if it will work.
#519
Post by izzo » Thu Aug 20, 2015 10:04 pm
RedBanner » Tue Aug 18, 2015 11:01 pm wrote:well loosing my rear diff, I knew it wouldn't hold up long, kinda screwed too because flatcat ows me a diff, but you know how that goes, Tristan sr.
:rofl:
#520
Post by RedBanner » Tue Apr 12, 2016 1:27 am
well I think me and my old buddy got things worked out! could have this on the asphalt again before too long! so excited.... trying to fight the urge to swap the struts and lower it, but that dear carcass I stratlold last year has me sketchin . also eagle adam found and sent me a stearing arm that I broke and couldn't find. I also got some more front end bits, but need a pitman arm bad, my current one is off of a 710, wich is different than the 1200 one, either I need the one with the stud, or the one with a hole... cant remember now that I'm not under it.
