71 blue & Black coupe
Morrisun
Post by Morrisun » Sun Oct 06, 2013 6:17 pm
Dave and I picked-up this 1971 coupe yesterday in Hillsboro.
The drivers side had some rust in the floor pan, but not bad!
All the grommets are intact-ed.
No rust in the spare tire well.
Hasn't been hit in the front!
Has an A14 with a B210 H510 rear end and flipped rear springs-no transmission.
Good dash pad and glove box door-needs gauge panel.
Good glass, a very solid 1200 coupe.
Re: 71 blue & Black coupe
Post by izzo » Sun Oct 06, 2013 6:46 pm
Wow Doug,
This is a good start!
MicroMachinery
Post by MicroMachinery » Sun Oct 06, 2013 8:24 pm
Great find!
RedBanner
Title: MasterBlaster
Post by RedBanner » Sun Oct 06, 2013 10:24 pm
Looks pretty good!
Gray
Cars: '74 4dr B210, '71 1200 coupe, 2015 Leaf, and a 2014 Toyota Sienna.
Has thanked: 15 times
Been thanked: 17 times
Post by Gray » Mon Oct 07, 2013 6:27 pm
:fyea:
Neat! How do you keep finding these?
aka Dguy210
Morrisun
Post by Morrisun » Mon Oct 07, 2013 7:11 pm
I find them by talking to EVERYBODY that asks me about Smurf and many had one or rode in one. So do you know of any sitting around? These last two came from a guy a spoke to over 5 years ago. This one is a 71and I wanted an early car. this one changes to drive train- A14 and B210 rear end ONLY. Strongly considering putting a 1200GX engine, flat top pistons... and down the rabbit hole we gooo! I have collected most if not all the parts- NO, still need a camshaft-
RedBanner
Post by RedBanner » Mon Oct 07, 2013 10:38 pm
Im going to be looking further into what cam I need, also, got a spring catalog out to see if I can find a cheaper spring than the aftermarket ones ive found. What springs do you and dave run?
Morrisun
Post by Morrisun » Tue Oct 08, 2013 7:36 am
I am patiently waiting for an engine builder with a flow bench to get to my H89 A-series cylinders heads. He has in the passed installed small block chev- 1st gen, valves and springs in Datsun A-series heads. And yes the valve stems are shorten and use chev valve stem seals. I had an A14, race engine that used Isky springs 455-JA-006, specs- http://www.iskycams.com/pdfcatalog/2004-05/page49.pdf, still need dual spring retainers, cost $115 dual springs inner and outer MAX RPM 10,000. Once switch over to chev valves more choices of sizes and materials.
Dave has stuck pretty much to the Nissan parts in his Dan Hart A14 engine, which runs flat tops pistons and a fairly streetable camshaft- it moves out quite nicely- even with me in the car!
RATDAT3
Cars: 1966 411 4 door
1967 411 Wagon
2002 Nissan Frontier 4x4 (Storm Trooper)
Post by RATDAT3 » Fri Nov 08, 2013 9:18 pm
Again, you are the 1200 Keeper! This is great! I'm so glad I want a wagon--cus these are making me drool!
Guitars, cars, and beer make for a great day!
