75 620 DD for my dad
Eagle_Adam
Re: 75 620 DD for my dad
#61
Post by Eagle_Adam » Mon Oct 28, 2013 11:09 am
but the light turns off at idle......
Has thanked: 3 times
#62
Post by flatcat19 » Mon Oct 28, 2013 9:50 pm
Correct pulley size?
I recall Ed's 521 alt pulley being too big?
Wouldn't charge at idle, but would when revved.
Is yours too small?
Has thanked: 4 times
Been thanked: 17 times
#63
Post by Laecaon » Mon Oct 28, 2013 10:15 pm
Its charging fine. It was charging in the 13v range at all rpms... Just the light would come on any time above 800 rpm...
#64
That gives me a new idea though... More volt metering!
#65
Post by flatcat19 » Mon Oct 28, 2013 10:37 pm
Isn't 13.0 too low?
If I see anything near 13.6V I'm selling an alternator.
But I also have cars with multiple very expensive computers.
Been thanked: 9 times
#66
Post by wayno » Mon Oct 28, 2013 11:06 pm
Make sure all your wires are good, and I hope you have a internally regulated alt, otherwise it's a nightmare, I gave up on externally regulated alts, I could not get the light to go out the last couple years, even though it was charging fine, but when it did quit, it was a surprise, as I mentioned, the light had been on a couple years.
#67
Post by Laecaon » Mon Oct 28, 2013 11:10 pm
I didnt say 13.0, I said in the 13s Like 13.5 or 13.7...
Its externally regulated, and in that case I take anything from 13.5 to 14.8 or so. I find the external regulators do as they wish, even with adjustments (mechanical type), and you just have to get one that works right.
It was 13.5 at like 1k with lights, anything above the battery voltage is technically charging.
#68
Post by flatcat19 » Mon Oct 28, 2013 11:49 pm
I see.
Eagle_Adam
#69
Post by Eagle_Adam » Fri Nov 08, 2013 12:51 pm
so this happened the other day...
in the rain
in the dark
without a jack that would fit under a lowered truck
without a spare tire in the truck
in the middle of an intersection
and i couldn't just drive away cus the fucking U bolts for the lowing blocks were stuck in the asphalt cus i never trimmed them
Eagle_Adam
#70
Post by Eagle_Adam » Fri Nov 08, 2013 12:52 pm
since i couldnt find a white wall tire to match on short notice i slapped on my spare set of wheels from my 74 that was totaled
i like the black better!!!! but id like to se the white walls make a return soon
Eagle_Adam
#71
Post by Eagle_Adam » Thu Nov 21, 2013 10:49 am
always something....
pulled out my spare and tossed it in
#72
Post by izzo » Thu Nov 21, 2013 11:05 am
amen to that comment. Always something.
Eagle_Adam
#73
Post by Eagle_Adam » Fri Jan 17, 2014 11:47 pm
Haven't been able to drive the truck for a few weeks......
But I finally got time to work on it today!!!
Ended up that the battery had shit out and one of the front wheel cylinders decided to shit out too....
So I'm ordering parts tomorrow
Eagle_Adam
#74
Post by Eagle_Adam » Sat Mar 15, 2014 9:38 pm
Brakes came out good, but the work never ends
Developed an exhaust leak...
Off with the carb and mani's
Fresh gasket
Finally added a PCV valve
All better
Eagle_Adam
#75
Post by Eagle_Adam » Tue Mar 18, 2014 1:04 pm
accelerator pump decided life wasnt worth living anymore....
Eagle_Adam
#76
Post by Eagle_Adam » Wed Mar 19, 2014 12:48 pm
New accelerator pump is in, fresh carb tune but now I think it needs re-jetted....
Oh well that can wait a while
Eagle_Adam
#77
Post by Eagle_Adam » Wed Mar 19, 2014 10:32 pm
i just bought a conversion kit for the Weber. I'm tired of the electric choke........
so a conversion kit to run a manual choke is on its way!
#78
Post by Laecaon » Wed Mar 19, 2014 11:50 pm
Electric chokes are weird. Or rather, Manual chokes are sooooo simple and 100% user controlled!
Brown
#79
Post by Brown » Sat Mar 22, 2014 8:16 am
I prefer manual so much more. good call. I need to change mine over as well.
#80
Post by izzo » Sat Mar 22, 2014 8:45 am
I prefer manual ones too. But a properly setup weber with electric choke.. You should be able to tap the gas once or twice, turn the key and it works as it should. Something is out of whack, yo!
Locked
