Has thanked: 58 times
Been thanked: 91 times
#621
Post by Laecaon » Fri Mar 01, 2019 5:30 pm
I can confirm I bought a bunch of M10x1.25 from belmetric...
Been thanked: 36 times
#622
Post by HRH » Fri Mar 01, 2019 6:24 pm
Lol, in my head the "VG30!!" alarm is going off. :D
#623
Post by HRH » Mon Mar 04, 2019 8:14 am
Ordered some more parts, talked to Ricky at Raw Brokerage. He said basically any of the Japanese engines you get can be condsidered a black box. Some are good, some look like garbage, just depends. Confirms my theory. Anyway, stud kit is coming and some various gasketry. Just as well it's late, it's been super cold here lately. Next week should be a bit warmer where I'll actually want to be in the garage. As it was, I've been playing outside melting ice dams on the roof and picking up frozen dog poop. Whee!
Has thanked: 261 times
Been thanked: 140 times
#624
Post by DRIVEN » Mon Mar 04, 2019 9:00 am
If you get bored you can always come down to my place and kick tumbleweeds off the hill and watch the wind stack them against the fence. It's already 33 degrees here. Suns out guns out.
#625
Post by HRH » Mon Mar 04, 2019 10:00 am
Lol, it was 8 degrees this morning when I woke up. It's a warm 24 degrees now! :) Tonight should be the last of the super cold, then we get back to the 30s.
#626
Post by HRH » Wed Mar 13, 2019 7:34 pm
Ah yes, boiling out water outlet pipe connected to intake manifold. Fun fun, finding lots of pits and can't find a replacement part online! Boooo! Can't bypass either, it's the upper radiator house outlet as well. Really cockward design.
#627
Post by DRIVEN » Wed Mar 13, 2019 7:38 pm
DRIVEN wrote:
Sun Jan 20, 2019 6:19 pm
DRIVEN wrote:
Mon Jan 14, 2019 5:39 am
Yes. Because Nissan.
#628
Post by HRH » Wed Mar 13, 2019 8:58 pm
I sent an email to rawbrokerage tonight to see if they can locate a new water pipe. Either that or I'm going to have to replicate it. I'd just weld onto it, but it's so damn rusty, I'm thinking a new pipe would be a better idea.
#629
Post by DRIVEN » Thu Mar 14, 2019 6:09 am
Wow! Where is it leaking?
#630
Post by Laecaon » Thu Mar 14, 2019 6:25 pm
Yea, luckily for me that stuff on the manifold/block are fine. The rest of it looked like shit, So I went full stainless on my coolant system.
#631
Post by HRH » Fri Mar 15, 2019 5:52 am
Can't tell, it's very small. I have dad working on it since he's a hell of a lot better welder than I am. The outlet tubes are pock-marked to beat shit. I filled in one hole already but pressure bleeds off ever so slightly. Think I'm going to have him re-weld where it's soldered or whatever. He should be able to turn some new outlets on the lathe.
Oh yeah, part is NLA from Nissan.
#632
Post by HRH » Sat Apr 27, 2019 7:58 am
The RB is getting closer to being finished! Finally got all the water lines sorted, intake and exhaust is back together. Working on the Nissan Quest 110 amp alternator swap, then onto fixing the wiring harness where it got drug around by the engine supplier.
I have the next two days off, missing a few pieces, but if I get lucky, I might get the engine actually in the car minus transmission, flywheel, ps setup and ac. Time will tell! Then I still need to get a new fuel pump, aftermarket intercooler setup since I didn't get an intercooler with this engine. Boooo. Wish I would have, the old airbox space would have been perfect. Looking at a frontmount for cost and simplicity, though I would like to hide it and a front mount is pretty obvious. Or I could go Subaru and take Ugly Betty's old hood and make a cutout for the intercooler on it? ;) Probably not, but you never know.
#633
Post by HRH » Sun May 19, 2019 9:43 am
Alright, finally got to test fit the engine yesterday. No go. Mounts are about 2.5-3" off. Engine mounts that came with the RB are good on one side, the other has a rip at the top, so can't use it. So we dicked around with making some mounts, which is certainly possible, and I checked the 910 RB swap thread on Ratsun, but his car had the diesel and I suspect it's much different. He said he used the RB20 mounts and it fit in with some minor modification. I don't see how that's possible, or the diesel Maximas have a different crossmember.
Either way, he did mention the similarity of the 240sx to the 910, oddly. And sure enough, it looks pretty close on the crossmember, rack set up to me. And knowing the Z24 block and KA block use near the same spacing in the hardbody, and they fit for the KA 240, I figure it's a pretty good bet if I buy a RB mount kit for 240sx, it should work with or without minor modifications on the 910.
So I ordered the kit and some 240sx mounts, we'll see if my theory is correct. But as far as a near drop in, nope! At least it's getting closer though.
Has thanked: 27 times
Been thanked: 149 times
#634
Post by wayno » Sun May 19, 2019 1:19 pm
My SD series engine mounts are farther forward(4"???), and my oil pan doesn't look anything like a L or Z block oil pan, it actually has 2 drain plugs as the oil pan has 2 sumps, one on both sides of the cross member, Nissan just made the diesels fit into the chassis, same thing your going to have to do.
#635
Post by Laecaon » Sun May 19, 2019 2:28 pm
My CA bolted onto the 510 crossmember just fine. (Oil pan problems aside).
Considering the Maxima is L series, it should be pretty similar.
#636
Post by HRH » Sun May 19, 2019 4:15 pm
Yes, I know I'm going to have to make it fit Wayno! ;) That's why I ordered the S13 mounts. I suspect they will make it fit perfectly being it's the same behind the crossmember for length and the similarity of the crossmember to the 910. I do suspect the diesel crossmembers are different though as the previous builder said he only had to modify the mounts by about a 1/2". Not anywhere near as much as I'll have. And as far as I know, there's only that one other wagon that has an RB installed.
