The "Retired" 510
Has thanked: 42 times
Been thanked: 14 times
Re: The "Retired" 510
#501
Post by DRIVEN » Wed Sep 20, 2017 6:21 pm
Ugh. Nissan plumbing is ridiculous. I think you're wise to eliminate all you can.
noflers
#502
Post by noflers » Thu Sep 21, 2017 7:16 am
So I must have had this leak all along. The radiator cap doesn't even get hot while idling in my driveway now. But I found that my heater control valve leaks when it's closed off and the system is pressurized. Does just fine when it's open though. I'll be looking into a replacement now, but I want to find something I can open and close mechanically with the 510 lever. Electronic sounds good until I remember I'll have to put a switch or button somewhere to control it. Trying to keep the interior as stock as possible...
Techflex will be here today, I'll see how it goes.
#503
Post by DRIVEN » Thu Sep 21, 2017 7:47 am
Those heater valves are rebuildable. Mklotz used to have a little tutorial on it. Just a couple Orings IIRC.
Has thanked: 4 times
Been thanked: 17 times
#504
Post by Laecaon » Thu Sep 21, 2017 8:29 am
I rebuilt mine. Probably a one-time rebuild. You have to pry some brass tabs out of the way to open it. Then bend them back to close. I nearly broke one. Just used a oring kit from Napa.
noflers
#505
Post by noflers » Thu Sep 21, 2017 9:11 am
Not sure if I mentioned it before, but I did rebuild it. Used oring part numbers at Napa from a tutorial I found. The process went smooth, nothing broke and it all went back together fine...
I got an assortment of vacuum caps and coolant caps this morning. Should clean my make shift plugs up great.
noflers
#506
Post by noflers » Fri Sep 22, 2017 7:18 pm
I ended up bypassing the heater completely and I've still got a leak somewhere. I'm kinda stumped on this to be honest. I also would rather not spend all my time away from work on the car.
Despite the issues, my friend convinced me to shoot a short video featuring my car for his YouTube channel. I'll link it whenever they post it up.
noflers
#507
Post by noflers » Tue Sep 26, 2017 12:09 pm
Been spending the past few days working out this issue. It's all making me want the excessive intake manifold again. But I'm not paying retail, that's for sure. I'll wait until a used one pops up. That wouldn't fix the problem, but it'll make me happy in other ways. Lol
And just to rule it out, I got another new radiator cap. While I was fiddling with that I realized I might have been screwing the cap on too tight. I was putting pressure down on the cap while screwing so it would go up over the "stops". If I didn't do that it just seemed way too loose. Anyway, I ran it with the cap where I think its supposed to be and it held fine. Now I've done a proper bleed on the system and I'll fire it up later to see how it does.
noflers
#508
Post by noflers » Tue Sep 26, 2017 5:01 pm
I found it! Well I found one, but only one. It's the freaking bleeder bolt! I'm going to tap it to the next size up because the threads are looking extremely unhealthy. What in the hell, why did that take so long?
#509
Post by DRIVEN » Tue Sep 26, 2017 5:41 pm
Always somethin'
noflers
#510
Post by noflers » Wed Sep 27, 2017 12:58 pm
I got all geared up to tap NPT threads this morning, but when I was getting ready I noticed that the hole had a crack in it. Wow, lol. I won't be getting to this until I find a replacement upper intake manifold. Yay, I get to take that off again. This time I'll be very thorough in my deletes, before I install it.
Tomorrow I'm leaving again for a couple more months. I should be back mid December or so. Then I'll have plenty of time to take care of this. Was it Indy510 that did the major cleanup and polishing of the KA intake manifold?Anyway, I'm gonna go find that and take another look.
#511
Post by DRIVEN » Wed Sep 27, 2017 1:55 pm
It was Indy.
Your KA luck is horrible.
noflers
#512
Post by noflers » Wed Sep 27, 2017 5:00 pm
Eh, part luck, part dumb ass probably. Who knows how long that's been cracked. But yeah, at least I'm getting to know the KA pretty well.
#513
Post by Laecaon » Fri Sep 29, 2017 2:40 am
That sucks.
So bye til December?
Indy510
Has thanked: 5 times
#514
Post by Indy510 » Fri Sep 29, 2017 10:32 am
Polishing the intake was way too much work. I had to hide all my threads and photos after the bringatrailer nightmare, but you can see a couple photos of it here: https://bringatrailer.com/listing/1975-datsun-710/
#515
Post by Laecaon » Sat Sep 30, 2017 2:25 am
Yea, Indys thread is in a deep deep hidden part of the forum. If you ask kindly, I can search through the drudge...
#516
Post by izzo » Tue Oct 03, 2017 9:16 pm
Bummer about his thread
Any updates?
noflers
#517
Post by noflers » Thu Nov 23, 2017 12:01 pm
Good bye til now. Lol
I'm back and I'm ready to get some work done on the car.
First I need to get a replacement upper intake manifold. One of these dry days I'll get out to pick and pull for it.
Then I'd like to find steering knuckles with a 14mm ball joint stud hole so I can replace the ball joints with the new ones I have.
And one last thing for my little wish list. Replace the rear subframe bushings. I have poly ones, but think I'll hold out a little longer for rubber ones.
And of course there will be tons of little stuff to do along the way.
#518
Post by DRIVEN » Thu Nov 23, 2017 1:33 pm
...aaaand he's back.
noflers
#519
Post by noflers » Fri Nov 24, 2017 9:42 am
Tore the intake mani off this morning. It gets easier and easier every time! :)
Today seems like clear weather. Might get to pick and pull soon.
#520
Post by DRIVEN » Fri Nov 24, 2017 9:49 am
They're having a sale. Grab spares.
