Adam's annoying ass green 620
Eagle_Adam
#41
Post by Eagle_Adam » Fri Aug 02, 2013 7:32 am
well, after a night of drinking at a company party im at work early to prove a point to the CEO (who called me out on my drunkenness and said i wouldn't even make it to work) Which means i can get off work early to go pick up my truck from the exhaust shop!!
Woot woot! cant wait to hear what she sounds like now :D
#42
Post by izzo » Fri Aug 02, 2013 9:20 am
I can't either :lol:
Videos!
Eagle_Adam
#43
Post by Eagle_Adam » Fri Aug 02, 2013 1:24 pm
spending $$ like its going out of style!!!
just bought everything for the rear disc swap, just need a MC and PnP should have one for me tomorrow!!!
#44
Post by flatcat19 » Fri Aug 02, 2013 6:15 pm
I have never understood why people want to use a used master cylinder.
It's the heart of your braking system.
Maybe I've just seen too many bad things.
It just scares me. I'm a wimp that way, I guess.
Hope you find one!
Eagle_Adam
#45
Post by Eagle_Adam » Sat Aug 03, 2013 5:39 pm
I've pulled too many "new" ones out due to failure right out of the box
#46
Post by flatcat19 » Sat Aug 03, 2013 7:22 pm
I get that.
Bot trying to put ya down.
You seem to have way better Datsun luck than I.
:lol:
Eagle_Adam
#47
Post by Eagle_Adam » Sun Aug 04, 2013 8:05 pm
FINALLY got the truck back from the exhaust shop, may have taken too long but it sounds great. Has a nice purr at idle and a good roar at WOT! Yet it's not annoying so I'm happy :D
Eagle_Adam
#48
Post by Eagle_Adam » Sun Aug 04, 2013 8:08 pm
But half way home......
Has thanked: 2 times
Been thanked: 2 times
#49
Post by RedBanner » Sun Aug 04, 2013 8:29 pm
[youtube]SzaSaksHBJM[/youtube]
#50
Post by flatcat19 » Sun Aug 04, 2013 9:08 pm
Sounds good.
Eagle_Adam
#51
Post by Eagle_Adam » Mon Aug 05, 2013 8:04 am
thanx banner!!!
Eagle_Adam
#52
Post by Eagle_Adam » Tue Aug 06, 2013 8:42 am
Banner and Kipp came over yesterday to hang out and turn wrenches!
had to buy a new multimeter that doesnt lie to me to find out my alt is only charging at 12.2...........
So now i need to figure out an IR alt swap,
Eagle_Adam
#53
Post by Eagle_Adam » Tue Aug 06, 2013 8:55 am
next up was the brakes! why? because they decided to fade to nothing OMWH from work yesterday! YAY!!!! im super excited
I had been previously told about this "mystery" valve that only late model trucks have..... hmmmm a mystery valve in my braking system. that could explain a lot...
this was the info i had to work with, pretty good info too IMO
Pic of said valve
first set of instructions
"Bleeding should be conducted in the following order : master cylinder, load sensing valve, right rear, left rear, right front, left front.
theirs 3 bleeders on the load sensing valve.
start with the front one ~ reason is, the brake line is from the masters, enters in front of it and flows towards the bleeder. This bleeds for the front brakes.
then bleed the rear one, reason is, this bleeds the rear brakes and fluids flows towards the bleeder.
then the middle one, reason is, it's the only one left.
here's a pic so you can see what I mean."
Second set of instruction
"i was looking st my chiltons and this is the procedure they say to bleed the entire system. sounds sucky lol.
Image"
Armed with that and a few friends to help pour fluids, bleed bleeders, and pump the pedals we were off!
Eagle_Adam
#54
Post by Eagle_Adam » Tue Aug 06, 2013 9:06 am
So the mystery valve was found, and found to be mal-functioning IMO
Here's a vid
http://s1356.photobucket.com/user/Eagle ... 2.mp4.html
Kipp was over and I listened to his truck and it sounds nothing like mine.
So it will also need replaced during the brake upgrade.....
Eagle_Adam
#55
Post by Eagle_Adam » Tue Aug 06, 2013 9:28 am
So long story short im replacing my whole braking system minus the hardlines, booster, and front calipers.....
also time for an IR alt upgrade....
ugh.... more $ spent in places i didn't wannna spend it
and im going to have to do my brakes in 2 parts...
master cylinder and NLSV first to make sure both those function correctly
then the rear discbrake upgrade and rotors/pads for the front...
Eagle_Adam
#56
Post by Eagle_Adam » Tue Aug 06, 2013 9:29 am
BUT!!!!!
even tho she cant stop under her own power for shit right now, and i have to drop more $ into then intended(isnt that always the case?), she still a sexy bitch after a bath!
#57
Post by flatcat19 » Tue Aug 06, 2013 11:53 pm
Why not eliminate the LSV? Unless you haul lots of heavy stuff all the time it really is not needed.
You should have no problem finding an IR alt.
Ed delivered a brand new KA alt to me last time I was there at 11:00 at night.
Did that window regulator ever make it your way?
Eagle_Adam
#58
Post by Eagle_Adam » Wed Aug 07, 2013 8:07 am
i am eliminating the Valve....... just need to figure out the softlines to do it!
as for the IR alt, i just need to find thw write up and read it
no the reg hasnt made it to me, he seems to want me to come get it and hes 30 - 45 min from me so that will have to wait :/
but, ifyou willing to throw some things in a box for me i can give you a list of what i need for my dads truck
#59
Post by flatcat19 » Wed Aug 07, 2013 9:10 pm
Eagle_Adam wrote:i am eliminating the Valve....... just need to figure out the softlines to do it!
I told you to send me a list. If I have it.
I'm gonna call the scraper in a few days.
Eagle_Adam
#60
Post by Eagle_Adam » Thu Aug 08, 2013 8:30 am
i know... i keep getting distracted...
and now ive fucked off for too long cus i can ship the stuff here before blue lake....
how the gauge bezel?
