Curious.
Are the 79 210 rear brakes self adjusting? I swapped old shoes with new shoes. and the drum went back on fine. I tried adjusting it some as there is a little star inside, but i don't know if i'ts self adjusting?
the little star is on the e-brake assembly. I pulled the e brake a bunch of times and took it for a spin hitting the brakes a bunch. it slows down and stops like it should now but i want to make sure it's adjusted right before letting her scoot to work in it.
210 rear brakes
210 rear brakes
Re: 210 rear brakes
Found my book.
210 is self adjusting with the parking brake cable. So I will jerk it a few more times (bahah) and make sure its nice and set I suppose. Time to do a little more reading.
- datsunmike
Re: 210 rear brakes
It's a ratchet assy. When there is enough brake shoe movement from wear, the lever can move behind the star wheel and moves it one click tighter on the return stroke, which removes the slack. It should try to do this automatically any and every time you use the brakes but only actually adjusts it when thee is sufficient slack.... and only if the star wheel is well lubed and not seized up.
If retracting the shoes in order to remove the drums you will have to reach in with a screw driver and push this lever away from the star wheel as it will not allow loosening.
The 720 got these around '82/'83
Re: 210 rear brakes
oh? I thought the 80 had them also. Could be wrong, All i did was replace the wheel cylinder a few years back and can't remember wtf it was like in there. But the brakes have always held tight even after 14k miles have been put on. E-Brake is dead on, and so are the brakes. right at the top like they should be. stops very well.
Re: 210 rear brakes
nevermind.
I do remember now. they have the star adjusters at the bottom. you can get to them from behind the backing plate and there is a rubber cover....
