74 620 wiring
74 620 wiring
Post by izzo » Fri Sep 06, 2013 1:16 pm
need help with 74 620 wiring
For the key switch, there are five wires
Someone cut them, and so I don't know where they go on teh key tumbler.
The 5 wires are
blue with white
Black with red
Black with white
A thick white wire
Black with yellow
Plz halp so i can put some connectors on there and get it back on the key switch so i can test fire this ma fucker!
Has thanked: 58 times
Been thanked: 91 times
Re: 74 620 wiring
Post by Laecaon » Fri Sep 06, 2013 4:40 pm
Blue White - Radio (seems odd but thats what the wiring diagram shows...)
Black Red - Coil Positive Direct
Black White - Also Coil Positive, but through the Ballast resistor. Also feeds the Ignition on Fuses at the fusebox.
White - Turns into a Black wire at the fusebox, goes to Battery+ through fusible link.
Black Yellow - Starter soleniod
Re: 74 620 wiring
Also, its in the "All Datsuns Info" .rar I got from you.
KlassicMotion
Re: 74 620 wiring
Post by KlassicMotion » Sat Sep 07, 2013 4:51 pm
Laecaon wrote:Blue White - Radio (seems odd but thats what the wiring diagram shows...)
Beautiful. I've got the same sort of issue. This will make work a lot quicker, thanks.
Re: 74 620 wiring
Post by Laecaon » Sat Sep 07, 2013 6:28 pm
For a 620? or a 510?
I can pull year specifics too.
KlassicMotion
Re: 74 620 wiring
Post by KlassicMotion » Sun Sep 08, 2013 7:54 am
I've got both, but it's the 620 that has some crazy wiring under the dash. I'm talking some household solid wire!! And a toggle switch and push-button ignition.
Re: 74 620 wiring
Post by izzo » Mon Sep 09, 2013 12:26 pm
Man, I got that info from the PDF file. I needed to know which wire went to what port in the plug on the back of the key tumbler :rofl:
Hope this helps someone else out for those who buy a 620 and the plug is cut off :x
Re: 74 620 wiring
Post by Laecaon » Mon Sep 09, 2013 1:59 pm
Oh... Coulda told you that too, bit now I'm at work...
Re: 74 620 wiring
Post by izzo » Mon Sep 09, 2013 2:15 pm
I don't have a way to look up the B210 stuff at work to compare to 620, but I'd be guessing its similar to this, Jacob?
http://datsun1200.com/modules/myalbum/p ... p?lid=4973
The DZ start works on the 510 and the 620, yet the wiring colors are a little different IIRC. Probably the same job duties across the cars just different wiring colors. The ALT wiring is the same on a 620 as a 510, and also the B210 so far I have found out.
KlassicMotion
Re: 74 620 wiring
Post by KlassicMotion » Mon Sep 09, 2013 6:10 pm
So you need to know what wire goes to what port in the back of the switch?....
It's in the wiring diagram you posted on the other thread...
Re: 74 620 wiring
Post by Laecaon » Mon Sep 09, 2013 6:35 pm
I think like this....
Just make it so the open port goes to the pinless spot on the switch.
Re: 74 620 wiring
Post by izzo » Mon Sep 09, 2013 8:55 pm
Klassic, where? I see something saying what wire does what, but not what pin out it goes to in the actual plug, maybe i missed it? please point me to that thread!
Jacob, thanks dude!
KlassicMotion
Re: 74 620 wiring
Post by KlassicMotion » Mon Sep 09, 2013 9:09 pm
Ehh, I was looking at the '73 620 diagram... Same thing though. It matches what's in my truck and Laecaon's pic. Although, the one in the diagram, pictures as if you are looking into the connector from the front (or the side that plugs into the switch)
So Laecaon's pic there; the BW to the left of the W is actually Blue White, and across from that is the Black White.
So here is my edit to Laecaon's. This is looking at the connector from the back as the wires plug into the connector:
______ BL/W _ W
BK/R _ BK/W _ BK/Y
Re: 74 620 wiring
Post by izzo » Mon Sep 09, 2013 9:21 pm
eh?
lol yours looks like jacobs to me :rofl:
Re: 74 620 wiring
Post by Laecaon » Mon Sep 09, 2013 9:29 pm
Oops yea blue white... Or LW....
yello620
Re: 74 620 wiring
Post by yello620 » Mon Sep 09, 2013 9:42 pm
IZZO, I am not sure if this will help or not, this was a 76 harness.
It is, blk/red, blk/wht, blk/yel
empty, blue, white
It can kinda be seen it the picture, but worth mentioning. The bumped side of the connector is at the bottom of the picture, so it upside down of the diagram posted several posts earlier.
KlassicMotion
Re: 74 620 wiring
Post by KlassicMotion » Mon Sep 09, 2013 9:45 pm
yello620 wrote:IZZO, I am not sure if this will help or not, this was a 76 harness.
Yes, this^^!!
This is what the other diagrams ^^ are supposed to be showing.
I would have posted a pic of mine, but like I said earlier, mine has issues too.... I only have three wires connected to it. :(
yello620
Re: 74 620 wiring
Post by yello620 » Mon Sep 09, 2013 9:54 pm
I have three different 620 parts harnesses and this is the only one that has five wires coming off of the ignition switch and I know that it is a 76 harness. The other two harness both have only four wires coming from the ignition switch, one of those harnesses is believed to be a 79 harness as has the wire for intermittent wipers, and the other harness is a early harness since it has the early style connectors for the dash lights to the heater.
Do you guys need a 6" pigtail cut to repair your harness? I think that one of these harnesses still has a connector that is not melted.
KlassicMotion
Re: 74 620 wiring
Post by KlassicMotion » Mon Sep 09, 2013 10:11 pm
I'm good, thanks. I just need to spend time with mine. Someone removed the ignition switch and put in a toggle switch and start button. :( I'm guessing I just need to find all the wires and put everything back together.
Re: 74 620 wiring
Post by izzo » Tue Sep 10, 2013 12:29 am
empty, blue, white
Dude you're awesome, thanks man!
