How To - Cheap rear main/thrust cap puller
Forum rules
Post by BLUE » Sun Sep 28, 2014 9:52 pm
Budget - rear main/thrust cap puller
In this How-To we'll be making a cheap dirty budget rear-main , and thrust bearing cap puller.
Required Materials
*Welder (arc/mig)
*Grinder with cut off wheel/Metal chop saw
*Drill press or drill w/drill bits.
*Safety glasses.
*Work Gloves.
*Scrap 3/16-1/4 bar stock (about 1ft will do).
*5ft of 1-inch or 3/4 square mild steel tubing.
(STEP 1) --- Building a trianglur shape to be able to bolt to the rear main , and thrust bearing caps (they are pre-threaded for this). The piece with the hole drilled in the center is what we'll be using.
Image007 by 71240z, on Flickr
Image008 by 71240z, on Flickr
Image010 by 71240z, on Flickr
A 9/32nd's bit was used I believe (it's been a while).
(STEP 2) --- Weld it all together like the picture below , and bolt it to the main cap.
Image020 by 71240z, on Flickr
Image022 by 71240z, on Flickr
Image028 by 71240z, on Flickr
Image014 by 71240z, on Flickr
(STEP 3) --- Cut (3) pieces of (1.5ft sections) of the 1-inch or 3/4-inch square tubing , and place (2) of the pieces on the block like in the picture below.
Image016 by 71240z, on Flickr
(STEP 4) --- Lay the 3rd piece that was cut in step 3 on the block like the picture below.
Image017 by 71240z, on Flickr
(STEP 5) --- Rear main cap pulling. This requires stacking (2) of the square tubes in the front braced across the block (like the picture below)) , and the third in the rear (like the picture below) , and finally sticking a pry bar through the center while lifting up to pull the cap.
Image031 by 71240z, on Flickr
Image032 by 71240z, on Flickr
Has thanked: 42 times
Been thanked: 14 times
Re: How To - Cheap rear main/thrust cap puller
Post by DRIVEN » Mon Sep 29, 2014 5:51 am
Crafty! Great option if you don't have access to a slide hammer.
Has thanked: 4 times
Been thanked: 17 times
Post by Laecaon » Mon Sep 29, 2014 11:34 am
I used a regular framing hammer, and a bar. Put a bolt in the cap, hook the hammers claw in the bolt, rest the head of the hammer on a bar like above, and pull on the handle.
