Volvo door seals (510)
Forum rules
Draynor
Cars: 71 510 wagon
Post by Draynor » Thu Jun 27, 2013 10:56 pm
Not sure if this should be in the "How to" or "Interior/Exterior". Please Move if need be.
So my stock door seals were pretty shot like most are. I could hear significant wind noise while driving and could see light coming through the cracks.
My cheap solution to the reproduction door seals that don't do a very good job at what they're intended to do. Volvo seals!
Went to the local yard and grabbed 2 front door seals off a Volvo 850 wagon I believe 91-97 is the year range. The V70's are also the same. I got both seals for less than $9 :). It is pretty straight forward to remove them, So I won't go into that.
Once I got home, I then started to remove the door sills and pinch welt on my wagon. I then took one of the seals and placed it where the old pinch welt used to be.
I then placed the door sill on top of the seal to see how much to cut.
Cut section
After that I placed the seal back on and installed the door sill. Great fit!
Total time to install, about 10 miuntes a side.
The sound proofing these provide is outstanding, It literally feels like a new car! Air tight, No wind noise besides what comes from my windows. It is a little tougher to close the door now, but I can live with that. This is a daily driver and these seals helped make it that much more enjoyable to drive :)
I plan to do the rears with the same seals. Will post up when i get to that...
Re: Volvo door seals (510)
Post by RedBanner » Fri Jun 28, 2013 12:47 pm
Great idea man, I need to do this pretty bad lol
Has thanked: 170 times
Been thanked: 84 times
Post by DRIVEN » Fri Jun 28, 2013 8:48 pm
Nice!
Post by 510freak » Fri Jun 28, 2013 9:59 pm
sweet stuff,total nwdatsuns
levigideon
Cars: 210, 510, 510
Post by levigideon » Sat Jun 29, 2013 2:58 pm
Thanks! I'll put this on my list of things I can do while I'm broke. :thumbs:
Has thanked: 7 times
Post by flatcat19 » Sat Jun 29, 2013 4:54 pm
Good write!
Draynor
Cars: 71 510 wagon
Post by Draynor » Sun Jun 30, 2013 2:32 pm
Thanks! Trying to come up with a rear hatch solution and some outer squeegees.
Post by izzo » Sun Jun 30, 2013 3:55 pm
is it close to a z hatch rubber?
Draynor
Cars: 71 510 wagon
Post by Draynor » Sun Jun 30, 2013 8:30 pm
Not sure, Never seen Z car rubber...
devilsbullet
Post by devilsbullet » Sun Sep 01, 2013 4:41 pm
I've got some sittin on my parts z in my garage you could have to experiment with. I dunno how good/bad of shape its in, but it could be used for measurement/fitment to see if it'd work at all before spending money on any.
PDX Matt
Post by PDX Matt » Mon Sep 02, 2013 1:31 am
That's awesome. Now there needs to be a cheap alternative found for the 620's!
Has thanked: 36 times
Been thanked: 57 times
Post by Laecaon » Mon Sep 02, 2013 1:57 am
PDX Matt wrote:That's awesome. Now there needs to be a cheap alternative found for the 620's!
Just use the same?...
PDX Matt
Post by PDX Matt » Tue Sep 03, 2013 10:48 pm
I suppose they would be the same wouldn't they. ;)
KlassicMotion
Post by KlassicMotion » Sat Sep 07, 2013 8:38 pm
In your picture it looks like you left the old seal on. Would the door shut better if you took the old one off?
Draynor
Cars: 71 510 wagon
Post by Draynor » Sat Sep 07, 2013 8:49 pm
I took it off before to try it out. It does shut easier. I left it on mainly for the bottom since the Volvo seal does not cover there since the door sills are there. I am going to eventually just take the old seal offf and cut it and leave the bottom section on.
KlassicMotion
Post by KlassicMotion » Sat Sep 07, 2013 10:08 pm
Cool. Thanks for the write up.
Jester
Cars: 1979 620 KC
Post by Jester » Sun Dec 06, 2015 3:20 pm
Thanks for the write up. There was an article on the other datsun page about using some Chrysler car seals. Good to know the Volvo seals work too. I will be trying these on my 620 soon.
BTW: I accidently gave you a thumbs down on this. Sorry. I can't figure out how to change it.
Post by 510freak » Sun Dec 06, 2015 3:51 pm
Jacob fixed it Jes
Jester
Cars: 1979 620 KC
Post by Jester » Mon Dec 07, 2015 9:33 pm
Right on. Thanks Jacob.
Draynor
Cars: 71 510 wagon
Post by Draynor » Thu Jan 14, 2016 11:40 am
Jester » Sun Dec 06, 2015 4:20 pm wrote:Thanks for the write up. There was an article on the other datsun page about using some Chrysler car seals. Good to know the Volvo seals work too. I will be trying these on my 620 soon.
No proboem! Hope they work out for you!
