Trans fluid
Trans fluid
Post by izzo » Thu Jul 25, 2013 12:04 pm
Topped off the 210 when I bought it....
GF says its acting funny, so I check the trans fluid and the dipstick is dry.. Threw some in it, had her drive it aruond a bit.... Topped it off after I got some more fluid...
Question is, where'd it go? I see no leaks anywhere. I checked the driveline input area, the trans pan seal, the lines... nothing, no drips on the ground. no wet spots (lol).
Re: Trans fluid
Post by draker » Thu Jul 25, 2013 12:20 pm
Does it have any vacuum actuators on it?
Re: Trans fluid
Post by izzo » Thu Jul 25, 2013 1:20 pm
Hmm shit. Didn't think of that. Will have to take a looksie
Has thanked: 45 times
Been thanked: 76 times
Re: Trans fluid
Post by Laecaon » Thu Jul 25, 2013 2:01 pm
Auto? Where do the tranny oil lines go? Into the radiator? check your coolant...
Re: Trans fluid
Post by 510freak » Thu Jul 25, 2013 2:22 pm
Might be a plugged modulator.
datsunmike
Re: Trans fluid
Post by datsunmike » Thu Jul 25, 2013 5:30 pm
Or an un plugged modulator.... :troll:
The diaphragm could have ruptured and vacuum will then draw ATF into the intake.
The Vacuum modulator valve is located on the left side about in the middle (just above the pan) and just in front of the electric down shft solenoid. It will have a short 'rubber' hose elbow to a hard line up to the intake. Pull it off and ATF may drip out if this is the problem.
If it is have a care when removing it. There is a small rod the diaphragm pushes against inside to 'adjust' the shift points.
The coolant lines are under no great pressure and the return line just empties back into the transmission case so if it was leaking, rad pressure would more likely force coolant INTO the transmission.
Re: Trans fluid
Post by izzo » Thu Jul 25, 2013 8:40 pm
Good to know, thanks mike!
Ill crawl under there tomorrow and take a gander. Napa auto parts wants 30 bucks for the part. Rock auto for the same part is 2 dollars lol. If its bad, then itll be fixed in a week..
I to notice a little smoke here and there out the tail pipe. mostly seems like condensation build up, but the gf notices smoke. So that maybe where its coming from, that or the master cylinder. but it doesn't go down fast enough to seem to cause a problem.
IDK. Guess it's just time to go thru it all
Re: Trans fluid
Post by 510freak » Thu Jul 25, 2013 9:00 pm
Years ago(early 90's), I picked up a primo old lady 510(for chump change)..Smoked more than I did.
ended up being modulator.
Re: Trans fluid
Post by izzo » Mon Jul 29, 2013 10:17 am
Update
Ordered the modulator. The smell when it bellows out smoke is kind of a diesel smell, and I crawled under and pulled the rubber hose like mike suggested. When I pulled it off fluid came out, not a lot but some. So it must be sucking it out then burning it off in spurts.
Module is in the mail and should be here this week. I will take care when removing it as suggested.
Re: Trans fluid
Post by draker » Mon Jul 29, 2013 12:03 pm
Ding ding ding... winner winner
Eagle_Adam
Re: Trans fluid
Post by Eagle_Adam » Mon Jul 29, 2013 12:59 pm
deff the governor/modulator man.
Had to fix that on the goon too
datsunmike
Re: Trans fluid
Post by datsunmike » Mon Jul 29, 2013 4:45 pm
Our first used Ford van at work started having more and more engine oil in it. Every time I checked it, it was higher. Trans was using oil but I didn't connect this. How does it get through the engine into the pan? It was the modulator valve. Shrug.
