Can't shift into gear while engine is running?
Re: Can't shift into gear while engine is running?
#21
Post by draker » Tue Sep 10, 2013 10:24 pm
Anyone have a spare 5 speed?
#22
Post by izzo » Wed Sep 11, 2013 7:48 am
Like a bawse! Those rear mains are pretty easy to do really. Use syl-glyde on the inside of the new seal before installing it :D That seal will outlast the car :lol:
datsunmike
#23
Post by datsunmike » Wed Sep 11, 2013 3:32 pm
Might as well replace the pilot bushing now while it's easy to do. Use a small screwdriver and split the old one lengthwise in 2 or 3 places and fish out the pieces. Try not to gouge the crank hole but a scratch is no big deal as it will just help hold the new one. Tap in a new one with a block of wood over it to protect it.
Ah, the age old question... grease the pilot or run it dry? Well I run them dry as this is how they are designed to run. Sintered bronze is porous like a sponge (and why it's so easy to split with a screwdriver) and has been soaked in oil so it is permanently lubricated. Grease will just attract abrasive clutch particles. Up to you.
#24
Post by draker » Wed Sep 11, 2013 8:18 pm
Yeah, I'll replace with the new clutch. Just another while your in there item. Another method to removing them. Fill hole with grease, insert clutch tool/dowl/whatever that's the same size and tap it in. Hydraulic pressure will push the bushing right out. But the tool you use must be a tight fit. Giggity.
I'm on the hunt for a 5 speed.. If I can find one, it's a good time to swap. If not, it's just a few bolts to pull it out again.
What I found interesting was the engine didn't have much movement when the trans was removed. I usually expect to see the engine supported so it doesn't put pressure on the mounts or whatever else. Without that movement it made it kind of hard to get the bellhousing to clear the firewall/trans tunnel. I didn't look too much into it since I had gravity on my side. Going back in will be a different story.
Are the rock hard hoses acting as a 3rd and 4th engine mount...?
Been thanked: 2 times
#25
Post by 510freak » Wed Sep 11, 2013 8:21 pm
draker wrote:Yeah, I'll replace with the new clutch. Just another while your in there item. Another method to removing them. Fill hole with grease, insert clutch tool/dowl/whatever that's the same size and tap it in. Hydraulic pressure will push the bushing right out. But the tool you use must be a tight fit. Giggity.
The grease method is a fine one(use it when I change pilot bushing),sounds funky too.
#26
Post by draker » Wed Sep 11, 2013 9:11 pm
Yeah, when I first heard about it I was like.. what the heck? But the first time I tried it.. I was amazed!
datsunmike
#27
Post by datsunmike » Thu Sep 12, 2013 5:37 am
If going hydraulic use ivory or some other soft soap. Just pack it in there... less messy. Splitting is way faster/easier. You can do it in the time it takes to read this post twice.
#28
Post by izzo » Thu Sep 12, 2013 10:47 am
It probably is the hoses. They kind of act like a shock or a damper w/e. Hoses are soft ish, but will keep the engine in line. If you jack up the front of the motor with them attached you can hear them tear inside (ask me how i learned this). Just undo the rad hoses and you'll have a floppy motor you can rock front or back. I usually put a 1/4" thick piece of wood board behind the motor to keep it from going back and smashing the brake lines just in case I go tommy fuckin torque on the jacking up the front of the motor.
#29
Post by draker » Thu Sep 12, 2013 11:56 am
Good info man, thanks! I have new hoses to put on... so it looks like those will be getting replaced the same time the trans is going in.
#30
Post by draker » Fri Oct 25, 2013 7:29 pm
This thread isn't dead... I'm in a holding period.
I was looking for a 5 speed to replace the tranny while I had the 4 speed out. I found someone selling the back half of a dogleg... then izzo was selling a broken dogleg. I bought both.
Once I get the other dogleg, I'll assemble and finally get some closure on this thread.
#31
Post by 510freak » Fri Oct 25, 2013 7:31 pm
Thats the way to get a dogleg :fyea:
Man on a mission
datsunmike
#32
Post by datsunmike » Fri Oct 25, 2013 8:16 pm
Uh......
Uh...
A short dogleg tail casing on a long dogleg ? This should be interesting. :fry:
#33
Post by izzo » Fri Oct 25, 2013 11:01 pm
I think he is just using the front half of the case of this one, to put on a good back short case dogleg, that was my understanding.. should be fine. the fronts were the same, the backs were different.
datsunmike
#34
Post by datsunmike » Sat Oct 26, 2013 8:23 am
I wonder why the front case would be missing? Maybe it was a Z series.
#35
Post by draker » Sat Oct 26, 2013 9:57 am
datsunmike wrote:I wonder why the front case would be missing? Maybe it was a Z series.
Guy parted the front case to someone else a while back.
#36
Post by izzo » Sat Oct 26, 2013 9:41 pm
Shit. Dude... im in Portland now at the hospital. Didnt even think of grabbing it
#37
Post by draker » Sat Oct 26, 2013 11:18 pm
Shhhhhhhhhhhhhhhheeeeeeeeeeeeeet..........
Next time.
#38
Post by draker » Tue Nov 19, 2013 12:13 pm
Clutch ordered. Need to get the flywheel milled.
#39
Post by izzo » Tue Nov 19, 2013 12:17 pm
sweet. and you gotta get your trans :D
#40
Post by draker » Tue Nov 19, 2013 12:27 pm
izzo wrote:sweet. and you gotta get your trans :D
I do!
I was thinking about installing the 4 speed again until I can get the two 5 speeds put together. We'll see how it goes.. I might just wait.
