need opinions on Ka trans for 74 620
datsunmike
Re: need opinions on Ka trans for 74 620
#21
Post by datsunmike » Thu Nov 07, 2013 7:58 am
Resident_kamakazi620 wrote:Farmerjoe aka Neil confermed the z24i trans at 30.5...and told me 720 driveline shortbox is an inch long than 620.... :fyea:
The As the two different wheelbase lengths are in the back of the frame, the front driveshafts with the carrier bearing should all be the same length. All bolt to the same place beside the torsion bar mounts. Well I'l write this down and add to my info. if and when let me know if you confirm this measurement.
How I measure them. As you can't measure through the center of the transmission you have to measure along a parallel line outside the case. If hooking your tape measure to the bell it should be held about 9" away from the driveshaft end using a straight edge to measure up to. Measuring from bell directly to the tail will be an incorrect longer slope distance.
Farmer Joe
#22
Post by Farmer Joe » Sun Nov 10, 2013 12:31 pm
get this figured out for sure?
KLH620 KA24DE FS5W71B HF37
