Cheap 1/2" 10mm impact bit .. I couldn't imagine impacting with this thing ... trollol.
022 by 71240z, on Flickr
plop... like a bawse !
034 by 71240z, on Flickr
Head-gasket looks good. Will be re-using it...
kidding... New HG
All the cylinders look pretty dang good ... can see cross-hatching in all of them and no scratches/scores/glazing !
028 by 71240z, on Flickr
--- Black ZXT ---
- Has thanked: 665 times
- Been thanked: 243 times
Re: --- Black ZXT ---
shot some pb blaster all the exhaust things !
Knocked off the down-pipe to get to the drain-plug.
012 by 71240z, on Flickr
Excellent play on turbine end (stock TB03 Ai-Research 280zx turbocharger).
011 by 71240z, on Flickr
Mineral deposits... tiny little trolls. Well played...
017 by 71240z, on Flickr
- Has thanked: 1185 times
- Been thanked: 1155 times
Those cylinders look great.
Indeed ! Thanks. Best part is you couldn't tell one cylinder from the other in pictures at a glance.DRIVEN wrote:Those cylinders look great.
I was a bit shocked to say the least
head on the left is for black zxt , and head on the right is from other zxt.
018 by 71240z, on Flickr
scraped off enough of the gasket surface(razor bladez) to use the Snap-On flat bars.
016 by 71240z, on Flickr
I removed ... just enough gasket material .... to use the flat-bar
015 by 71240z, on Flickr
knocked out (5) freeze plugs on the drivers side of the block.
014 by 71240z, on Flickr
013 by 71240z, on Flickr
You gots too many projects. I can't keep up.
- Has thanked: 1320 times
- Been thanked: 222 times
