rear drum annoyance.
Re: rear drum annoyance.
#41
Post by izzo » Mon May 26, 2014 9:49 am
take some 300 grit to the shoes and wear them down a LITTLE bit. or if you have a die grinder or whatever stick a fine pad on it and goto down for a second.... Just graze a little off there to ensure its not that.
The drums were non serviceable according to orielly assholes. So I don't think the drums are too thick, maybe just the shoes??? Give the sand paper a shot on the shoes and wear them down a smidge....
devilsbullet
#42
Post by devilsbullet » Mon May 26, 2014 10:37 am
maybe i'll hit both shoes and drum some, that drum still seems pretty thick.
Has thanked: 1 time
Been thanked: 13 times
#43
Post by Laecaon » Mon May 26, 2014 11:02 am
Have you with the drums removed, had someone push the brake pedal and watch the cylinder extend and retract?
devilsbullet
#44
Post by devilsbullet » Mon May 26, 2014 11:13 am
Ya that's part of what banner and I did yesterday. That's why we greased it, it the cylinder itself was opening and closing fine, it just wasn't sliding, so we cleaned it off and greased where it slides, moved ok after that.
devilsbullet
#45
Post by devilsbullet » Mon May 26, 2014 2:55 pm
problem solved. I didn't listen to my own rule #1 and make sure the shoes going on were the same size as the ones coming off. dunno why it worked ok for the drivers side, but the shoes I took off the passenger side still had tons of life in em, so I slapped em back on, readjusted, and drove around for about 30 minutes, braking at every opportunity. got home, checked the drums, no more heating up, and my brakes feel good, so good to go!
Has thanked: 1 time
#46
Post by flatcat19 » Mon May 26, 2014 8:38 pm
Problem solved. Post tits.
devilsbullet
#47
Post by devilsbullet » Mon May 26, 2014 9:43 pm
done, and done. god what I wouldn't give for 5 minutes with ava...
RedBanner
Title: MasterBlaster
#48
Post by RedBanner » Tue May 27, 2014 12:48 am
That leaves her 3 minutes to talk after words....
devilsbullet
#49
Post by devilsbullet » Tue May 27, 2014 8:38 am
I'm ok with that. She's a cool chick lol.
