Turbo L series
z chopper
Cars: possible '72 1200 coupe very soon.
Turbo L series
Post by z chopper » Wed Feb 19, 2014 5:35 pm
I have an L18e intake coming to me in a couple weeks. If I can track down an L20b block what head would be best for a turbo open or closed then for pistons flat top or dished??
z chopper
Re: Turbo L series
Post by z chopper » Wed Feb 19, 2014 5:53 pm
oops might have put this in wrong spot, can a mod move it?
Has thanked: 69 times
Been thanked: 104 times
Re: Turbo L series
Post by Laecaon » Wed Feb 19, 2014 5:55 pm
Its in a fine spot.
Has thanked: 4 times
Been thanked: 38 times
Re: Turbo L series
Post by jtinluvr » Wed Feb 19, 2014 8:36 pm
Compression depends more on how much boost you plan to run. 9:1 with under 10psi would be safe. Find a combo that gets you in that area. Turbos make up for a lot of flow deficiencies.
Mark
z chopper
Re: Turbo L series
Post by z chopper » Wed Feb 19, 2014 9:09 pm
I was thinking of a 280zxt turbo if that helps
Has thanked: 161 times
Been thanked: 43 times
Re: Turbo L series
Post by Taterhead » Thu Feb 20, 2014 6:12 am
Paging Blue, is Dr. Blue here?
dislexicdime
Re: Turbo L series
Post by dislexicdime » Thu Feb 20, 2014 10:32 am
LTB pistons with the deep dish
kittens and bj's
z chopper
Re: Turbo L series
Post by z chopper » Thu Feb 20, 2014 1:19 pm
LTB pistons?
MicroMachinery
Re: Turbo L series
Post by MicroMachinery » Fri Feb 21, 2014 12:51 am
L Twenty B? I know they drop right into an L18 and lower the compression.
RedBanner
Title: MasterBlaster
Re: Turbo L series
#10
Post by RedBanner » Fri Feb 21, 2014 1:14 am
I think the l18 pistons are 4 cc I think, l20b is close to 12cc.
L18, with open chamber head, l20b pistons, and 1mm headgasket is 7.77 to 1 compression
idk what the magic ratio is, before boost.
z chopper
Re: Turbo L series
#11
Post by z chopper » Fri Feb 21, 2014 2:03 am
ok good info
dislexicdime
Re: Turbo L series
#12
Post by dislexicdime » Fri Feb 21, 2014 10:59 am
kittens and bj's
z chopper
Re: Turbo L series
#13
Post by z chopper » Sun Feb 23, 2014 1:38 am
just thinking, maybe use 280zxt pistons since they should have the correct dish but I am sure the block would have to be bored even if using an L20b block. Then I am sure a cam oil spray bar would be useful also
dislexicdime
Re: Turbo L series
#14
Post by dislexicdime » Sun Feb 23, 2014 7:28 am
You only need the spray bar if you get a solid cam . Zx pistons will have the wrong compression you could use sr20det pistons
kittens and bj's
jayden71
Title: Bewb Captain
Cars: '71 Viagra blue 521
'79 Patina KC 620
Re: Turbo L series
#15
Post by jayden71 » Tue Mar 04, 2014 6:01 am
Soooo...pics of turbo L yet??
:fry:
:lol:
z chopper
Re: Turbo L series
#16
Post by z chopper » Tue Mar 04, 2014 10:14 am
jayden71 wrote:Soooo...pics of turbo L yet??
:fry:
:lol:
still waiting on parts
Jester
Cars: 1979 620 KC
Re: Turbo L series
#17
Post by Jester » Sat Jul 05, 2014 9:45 pm
A stock L20B has a static compression of 8.5:1 with a U67 head. If your going to put any serious boost to it you will at least want forged pistons. The L28 turbo pistons are 1mm over and will bring your static compression to 8.7:1. If your going to be pushing past the 10 pound point, you may want to think about O-ringing the block.
z chopper
Re: Turbo L series
#18
Post by z chopper » Sat Jul 05, 2014 10:02 pm
I am thinking like only 5 pounds of boost
Jester
Cars: 1979 620 KC
Re: Turbo L series
#19
Post by Jester » Mon Jul 07, 2014 12:15 am
5 lbs of boost will take you static of 8.7 and turn it to about 11.6.
Turbo's are cool. I have been reading some and really want to play with it on my truck down the road.
Good luck with yours. :thumbs:
Jester
Cars: 1979 620 KC
Re: Turbo L series
#20
Post by Jester » Mon Jul 07, 2014 12:17 am
Oh ya, this may be fun to play with too.
https://www.rbracing-rsr.com/compression.htm
