Am I an idiot?
Has thanked: 5 times
Been thanked: 3 times
Am I an idiot?
Post by Taterhead » Wed Feb 01, 2017 8:26 am
I'm working on putting zx struts on my sons 510 so it can be moved and this is what I'm dealing with. I took these off of an '82 zx myself but isn't the strut insert supposed to just slide out? I can't seem to pull this one out.
The gland nut
The inside of the strut tube
The cheapo replacement insert and gland nut looks like this.
They definitely don't look like the same thing to me. Is the one I have some kind of rebuildable horse shit?
Has thanked: 1 time
Been thanked: 13 times
Re: Am I an idiot?
Post by Laecaon » Wed Feb 01, 2017 8:40 am
Stock struts are not inserts. You can actually replace the fluid in them to change the dampening. But still it should come out. Mine did. You will pull a lot of fluid out though.
Re: Am I an idiot?
Post by Taterhead » Wed Feb 01, 2017 8:54 am
How did you get yours out? Take the rubber seal inside the strut tube out first? And then it slides out?
I have to do something since the actual shock piston will slide back down if I pull it up and let go of it. I just don't want to screw anything up as I don't plan on replacing these again for a while and zx struts ar getting harder to find down here.
Re: Am I an idiot?
Post by Taterhead » Wed Feb 01, 2017 11:14 am
Topic question answered. Obviously I'm an idiot. I removed the rubber seal and the old strut came right out. Thanks for your help Jacob
Re: Am I an idiot?
Post by wayno » Wed Feb 01, 2017 12:23 pm
I hate when that happens. :lol:
Re: Am I an idiot?
Post by Taterhead » Wed Feb 01, 2017 12:58 pm
Exactly, no kidding.
Got it.
Has thanked: 23 times
Been thanked: 6 times
Re: Am I an idiot?
Post by DRIVEN » Wed Feb 01, 2017 8:00 pm
This sure would be a good segment in a build thread ;)
Re: Am I an idiot?
Post by Taterhead » Thu Feb 02, 2017 6:40 am
Haha ^^ this guy.
noflers
Re: Am I an idiot?
Post by noflers » Mon Feb 06, 2017 8:35 am
Haha, I'm with "that guy". Never too many 510 builds!
Re: Am I an idiot?
#10
Post by Taterhead » Mon Feb 06, 2017 10:28 am
And I ran into the same problem that most do, lowered it too much and the tire hits the collar/spring perch. Yay for doing things twice.
Has thanked: 1 time
Re: Am I an idiot?
#11
Post by Laecaon » Mon Feb 06, 2017 11:47 am
Make sure to clock the spring perch for maximum low. I had about a 1/4" clearance.
