Volvo door seals (510)
Forum rules
Not sure if this should be in the "How to" or "Interior/Exterior". Please Move if need be.
So my stock door seals were pretty shot like most are. I could hear significant wind noise while driving and could see light coming through the cracks.
My cheap solution to the reproduction door seals that don't do a very good job at what they're intended to do. Volvo seals!
Went to the local yard and grabbed 2 front door seals off a Volvo 850 wagon I believe 91-97 is the year range. The V70's are also the same. I got both seals for less than $9 . It is pretty straight forward to remove them, So I won't go into that.
Once I got home, I then started to remove the door sills and pinch welt on my wagon. I then took one of the seals and placed it where the old pinch welt used to be.
I then placed the door sill on top of the seal to see how much to cut.
Cut section
After that I placed the seal back on and installed the door sill. Great fit!
Total time to install, about 10 miuntes a side.
The sound proofing these provide is outstanding, It literally feels like a new car! Air tight, No wind noise besides what comes from my windows. It is a little tougher to close the door now, but I can live with that. This is a daily driver and these seals helped make it that much more enjoyable to drive
I plan to do the rears with the same seals. Will post up when i get to that...
Cut section
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
Re: Volvo door seals (510)
Great idea man, I need to do this pretty bad lol
- Has thanked: 1168 times
- Been thanked: 1138 times
Nice!
sweet stuff,total nwdatsuns
- levigideon
- Cars: 72 510 Wagon
Thanks! Trying to come up with a rear hatch solution and some outer squeegees.
is it close to a z hatch rubber?
- devilsbullet
I've got some sittin on my parts z in my garage you could have to experiment with. I dunno how good/bad of shape its in, but it could be used for measurement/fitment to see if it'd work at all before spending money on any.
That's awesome. Now there needs to be a cheap alternative found for the 620's!
Just use the same?...PDX Matt wrote:That's awesome. Now there needs to be a cheap alternative found for the 620's!
- KlassicMotion
In your picture it looks like you left the old seal on. Would the door shut better if you took the old one off?
I took it off before to try it out. It does shut easier. I left it on mainly for the bottom since the Volvo seal does not cover there since the door sills are there. I am going to eventually just take the old seal offf and cut it and leave the bottom section on.
- KlassicMotion
Thanks for the write up. There was an article on the other datsun page about using some Chrysler car seals. Good to know the Volvo seals work too. I will be trying these on my 620 soon.
BTW: I accidently gave you a thumbs down on this. Sorry. I can't figure out how to change it.
Jacob fixed it Jes
No proboem! Hope they work out for you!Jester » Sun Dec 06, 2015 4:20 pm wrote:Thanks for the write up. There was an article on the other datsun page about using some Chrysler car seals. Good to know the Volvo seals work too. I will be trying these on my 620 soon.
