Waynos 1966 datsun 520 ute
Has thanked: 30 times
Been thanked: 165 times
#381
Post by wayno » Fri Jun 14, 2019 12:30 pm
Thanks for the link, they just make pre-made existing model sizes.
There is nothing on CL that I will inquire about today.
Has thanked: 65 times
Been thanked: 100 times
#382
Post by Laecaon » Fri Jun 14, 2019 12:46 pm
I said that...
But its all just basic aluminum channel with aluminum sided foam for the panels. Would be relatively easy to make.
#383
Post by wayno » Fri Jun 14, 2019 5:41 pm
It looks so much better with the new to me inner fenders that I don't care as much about hiding it now.
I would like something that kept it dry inside, that is why I mentioned a wagon top, but that is just another major project.
Since the weather got better I have not even drove this truck, I would rather drive the 521 kingcab, but I always had it covered because the windshield gasket leaks, need to fix that issue while it is dry outside.
Yes I know you mentioned that about the covers, I was just more or less being clear about why I was not chasing that, they are kinda expensive also, but I would not have an issue with that if I could order it by size.
My box inner dimensions are 69"L X 53"W, but I want the cover to be 72"L X 56"W, the reason is to try and keep the rain/water out of the inside of the box instead of it just sitting inside under the cover rusting everything.
