Silver bullet 210
- Skeletonbonez
Silver bullet 210
After the Sentra was in an accident. This was aquired.. '81 210 a15 5 speed. Been a daily since June/July.
- Skeletonbonez
Re: Silver bullet 210
Thanks dude. It's been such a trooper! Lifes been crazy but somehow im still alive. haha.. So I burned out an exhaust valve the day after halloween. Luckily it was a pretty easy fix for a first timer. Huge increase in power with the new valves, shitty rings still have me burning a ton of oil.
- Skeletonbonez
- Skeletonbonez
Bearing down on connecting rod 2. all that oil burning took me out of the race for a couple days! welp... here's the damage currently as of December 27th
mikes goon...
[/img]
mikes goon...
[/img]
Certainly doesn't look good!
where you living these days? I'm down to lend a hand anytime I can.
- Skeletonbonez
It's definitely fucked. Waiting to get a way to the shop to get an opinion on it. Just not going to carry a crankshaft across town today! haha
Craig, Levi and I ended up moving to South Eugene. Found a house with a garage that worked for us. I'll send you my updated info! After a summer of (almost) having a wedding, to birthdays, family visiting and moving life had finally gotten back to semi smooth! Lifes crazy man...
- Skeletonbonez
Measured out the diameter and the others measure .204mm and the damaged one is at .185mm with some light damage to the rod end as well.
- Skeletonbonez
- Has thanked: 1187 times
- Been thanked: 1156 times
Offset grind and high compression stroker build?
you can always have the crank welded and re ground, but $$$. best bet to find another. the guy I got my b210 from has a few motors for me I just need to get up there to get them... Maybe soon hopefully.
- Skeletonbonez
That's true. All the grinding shit is an option. Forgot about an a15 in storage. So there might be the solution. I think it's levis original white goons motor..
- Skeletonbonez
- Skeletonbonez
So ended up not being the white 210's original. We cracked it open, this mystery a15 that is. to find this
Looking over it, it appears to be a young buck Pistons look good, oil pickup clean. Not much sludge or any play anywhere. I think we're gonna run this block. Once parts arrive. That will buy me time to get the other one off the burner.
Certainly an easier fix than the other.
Ooooh nice. Love pics like this.
- Skeletonbonez
Cleaning and some more cleaning waiting for parts to arrive ..
And today's the day it all goes back together.
Feel free yall to come hang out. ill be here til late im sure
- Skeletonbonez
