temporary 510
- Eagle_Adam
Re: temporary 510
what all is left in order to drive it?
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
Re: temporary 510
Fuel cell miggt need replaced. Just got waterpump in. A good one. But Im debating tearing into the motor more before I fire it up. ... not because I think it wont run, actuly im possitive it will. But I just wanna know whats in there for sure. Instead of trust the po.s word for it. There are mixed opinions on who built what for who and how much. But I could run a fuel can inplace of the cell, and run it now.
So im thinking of sitting down and making 3 simple mostly indapendent lighting curcuits. Headlights, brakes, and blinkers. But im not even sure. Going to probably putt in the window regulators, but damn if I can find enough hard where.
- RedBanner
Re: temporary 510
Maybe make a jack that fits under the car.
- RedBanner
Re: temporary 510
Cam is isky sighned 510 lift, 290 duration. No lobe center info,
- Eagle_Adam
Re: temporary 510
5RedBanner wrote:Maybe make a jack that fits under the car.
isnt that why there was notches cut into the rockers?
- RedBanner
Re: temporary 510
Yep works great side to side. But space is well, extremly fucking limited in my "garage"
- RedBanner
Re: temporary 510
Thought about cutting a peice of mud flap to kinda fill the void, but push out of the way if I needed to use the jack point.
- Eagle_Adam
Re: temporary 510
So scrap that B210...RedBanner wrote:Yep works great side to side. But space is well, extremely fucking limited in my "garage"
- RedBanner
Re: temporary 510
Yeah... just had so many good times in it. Bad times too..... shit. I should.
- Eagle_Adam
Re: temporary 510
shit can that thing....... cant even give it away
- RedBanner
Re: temporary 510
.... damn it.
- Eagle_Adam
Re: temporary 510
think of it this way....
more $ for datsun stuff and working room
- RedBanner
Re: temporary 510
Yeah. Needs to happen.
- Jamee
- Title: Fluffer
- Cars: 1977 Datsun B210
- Has thanked: 3 times
- Been thanked: 10 times
Re: temporary 510
i almost cried when i saw that. you have no idea how bad i wish i had room for that!
- Eagle_Adam
Re: temporary 510
its not the first B210 hes scrapped......
probably not that last either....
- RedBanner
Re: temporary 510
Cranked her over, fired, made a weird noise and I killed it.
Had a broken lash pad, I looked them over but didnt check lash. #4 intake was loose. Could have found it when I was there if I had checked. Derp.
Chewed up the rocker arm, the lash pad, and the rocker spring. Also a couple nicks the #4 spring retainer but every thing looks ok. Cam looks great, new lashpad, I had 4 different sizes and lucked out and had one, rocker I used a stock one... its a little different than the others.. but im not sure it will hurt me. Going to rub some assembly lube on that one, and add some zddp's before I fire it back up.
Lash set cold..
Lash set cold..
- Danfiveten
Re: temporary 510
I keep thinking about this 510 lol, really hope you decide to keep it
I told the wife id love to buy it and she slapped me...i guess 2 4 doors are enough, but im like IS RACE CAR!
