They're nice and easy and can do it with just about any material you want.
materials
hemp boards. it's $10 a board and prob need 2 boards for all of em.
black vinyl. it was $12 for 9 yards? MORE THAN ENOUGH form joannes
cushion. get some sponge from a local upholstery shop or micheals. ( i already had some so didnt really search) its the stuff people put on couches or beds.
staples + staple gun. get the smallest staples from homedepot and sand em down halfway.
3m adhesive form home depot.
heat gun.
try getting a beaten up door panel that you have and replicate the size and shape.
cut the hemp boards to check the size and fit of the door panel. cut all holes of course. make sure you skim a bit short because the vinyl is extra thick.
get the vinyl out and let it lay in the sun to stretch. also heat gun after to get all stretches out.
get sponge and spray adhesive on it then lay on the rough sides of the board.
then adhesive sponge onto vinyl and heat gun it.
then pull on the vinyl around the wood and staple with thin staples so it grips the board but not poke through the vinyl.
when you slide them into the metal piece on the inside of a door, they may not fit. to widen, just get a screw driver and push in and through to widen.
then put in your car. and feels great.
I have some pics in my thread but here. was $60 total for me and got all four done and satisfied. I also had enough to do my kickers.
I have enough to finish my rear dash pad if i ever get to it.
BEFORE HAND. PLEASE EXCUSE MY CRAPPY PICS. MY PHONE ISN'T THE GREATEST
Here's the test fit.
here's the layering. vinyl on the bottom. cushion, then hemp board.
here's the completed product.
here's what they look like installed.
I made my kickers. a little beat up but because i let shit rest on it and it recovered.
I also didn't have any inner side skirts if you know what I'm speaking of.
Using the same method. except i just stapled the top because the vinyl was too thick for the aluminum, I made some.
pics there's a bit of lighting like i messed up around that bump but you just have to make slit on the bottom so the vinyl doesn't gather up.
hope this benefits anyone.
