So right now we are back on the site that was fracked about 2 weeks ago. The one with the cool dog! Its called the Mauser.
Anyways, all the fresh water that was pumped into the well is now coming back out, dirty. Mixed with oil and other goodies, frac sand and what not. Our job is to take this water to disposal.
This can be quite dangerous. The pressure coming out of the well (mother nature) is unpredictable. It can flare up at any time and if its strong enough, pipes can burst throwing lethal pieces of metal in your direction.
Safety is paramount!! And not the "garage" type safety either, lol
The biggest concern however, is a thing called condensate. It is the gasses that come up from the ground with the water.
That is not all steam rising from this tank. Mixed in there are deadly gasses. When entering the location, it is the responsibility of all drivers and the truck pusher on the ground to watch the wind sock to see which way the wind is blowing.
If there is no wind and you park a truck next to this tank, in that "steam", and leave your truck running, those gasses coming out will take over your truck engine and cause it to rev out of control. A 15 liter diesel engine does not like to rev over 2500rpm. The engine will suck this stuff in and take off. If the driver does not catch it in time by slamming it into gear with the brakes on, the engine will explode and burn the truck to the ground and anything else around it. Scary shit!!
Since we must run our engines for the pto to run the pump to suck the water on, the noses of our trucks must be upwind from this stuff.
I have not seen this happen but my cousin has and it ain't pretty.
