dual carbs
- Been thanked: 1295 times
Re: dual carbs
My dual SU setup also has a return line, I used the emissions line as my return, I bypassed that stuff in the fender well and piped it directly to the tank.
The bowl vents go directly to the airfilter on my truck, the back of the airfilter housing has connections just for that, maybe you can add fittings for that on the back of your airfilters.
You also must remember that you have 4 holes on the face of each of your SUs, two have threads to bolt the airfilters on, the other two are to vent the piston, or at least one is, you have to drill a hole for that vent hole, otherwise the piston will not move up and down properly, if it don't move up and down properly, it will never run right.
Re: dual carbs
I'll just leave it as is then.
I doubt they'll float a lot anyways so I hope I'll be fine.
Re: dual carbs
Drill the hole where?wayno wrote:My dual SU setup also has a return line, I used the emissions line as my return, I bypassed that stuff in the fender well and piped it directly to the tank.
My air filter is connected to both of those holes that are for the air.
- Converted_to_datsun
Re: dual carbs
I'll drill the holes in the air filter to make sure all are accessed correctly.Laecaon wrote:There are 5 holes. 2 mounting, 1 intake (big), 2 vents. Per carb
speaking of that, I always see people puting an air filter on the little spout on the valve cover but it spews OUT air?Converted_to_datsun wrote:There is also two holes near the top for the valve cover to vent to or the overflows
Re: dual carbs
Oh... see the air filter keeps it clean...draker wrote:But when the car is not running it's could allow dirt into the engine.
alright. I'll pick one up for the little spout.
Or where you talking about those return fuel lines?
Re: dual carbs
datmo wrote:Oh... see the air filter keeps it clean...draker wrote:But when the car is not running it's could allow dirt into the engine.
I think you will find out that at an idle air comes out of that hole(valve cover vent), it's called blowby, but when you rev the engine, mine sucks air in, that is why the manufacturer put that line into the air filter, the air blowing out gets sucked back into the carb, but the air getting sucked in is filtered air.
Re: dual carbs
So it sucks in filtered air.... gotcha!wayno wrote:datmo wrote:Oh... see the air filter keeps it clean...draker wrote:But when the car is not running it's could allow dirt into the engine.
so ill get a filter lol
Re: dual carbs
Actually the best thing to do is to buy PVC line and connect it to the back of your air filter
- datsunmike
Re: dual carbs
The overflow fittings should have hoses that direct any spilled gas AWAY from the hot exhaust manifold. Remember they are only there in case the float should stick or sink and the carb over fill. This may never happen, but you want to keep gas and hot manifold separate.
Now simply adding a return line won't work, as there is no reason for the fuel to push past the needle valve and into the carb when there is an open easier path back to the fuel tank. To increase the pressure on the carb side a restriction is placed in the return line. The fuel pump pushes fuel against this tiny pin hole and pressure builds and now is enough to force it's way into the carb normally.
Return lines are a great idea on any car as the fuel in the tank is constantly recirculated through the fuel filter. Think about this... dirt and rust do not accumulate in the tank. The filer collects dirt all the time and keeps the tank cleaner.
Restriction at the tank end of the hard line above the fuel pump.
please feel free to like this post.
The return line is not there for excess pressure. The L fuel pump is regulated at (about) 3 to 3.5 PSI. L20Bs tend to run hotter under the hood than earlier Ls. This can cause the gas in the fuel line to the carb, and the gas in the carb to boil. This is particularly bad when the motor is shut off in hot weather. Under hood temps soar to 200F or more and the gas in the lines will boil. Vapor in the hot lines prevents gas from flowing into the carb and the gas in the carb has boiled away.. starting is difficult to impossible. To reduce this, a return line is added and cool fuel is constantly circulated past the carb and returned to the tank.Converted_to_datsun wrote:A return is for excess pressure, those vents are in case of overflow. Wouldn't work properly
Re: dual carbs
what's the difference?Converted_to_datsun wrote:Actually the best thing to do is to buy PVC line and connect it to the back of your air filter
Going to the air filter will just filter it just as much as its own smaller air filter.
I think that it will be a good idea to get some hoses and just point the excess gas to the ground because you're right. gas + hot manifold = terror.datsunmike wrote:The overflow fittings should have hoses that direct any spilled gas AWAY from the hot exhaust manifold. Remember they are only there in case the float should stick or sink and the carb over fill. This may never happen, but you want to keep gas and hot manifold separate.
I do think the return lines are also a great idea but I feel like if it'll rarely happen, I shouldn't need to worry about making a whole return line for maybe an ounce of gas? more or less.
I'll put in my carbs tomorrow.
I'll definitely put some hoses and point the excess gas downwards or something along those lines.
Re: dual carbs
- datsunmike
Re: dual carbs
The difference is that when the blow by becomes more than the PCV can suck into the intake the flow reverses. Fumes blow out under the hood and stink up the cab. In addition the 'cute l'il blue filter' gets wet with oil and drips. When connected to the stock air filter the fumes (and any oil fog) are sucked down into the carb. This is a way better idea.datmo wrote:what's the difference?Converted_to_datsun wrote:Actually the best thing to do is to buy PVC line and connect it to the back of your air filter
An ounce or two?? Gas is flowing through the return all the time the motor is running. Imagine 3PSI squirting through that small hole. On a long trip gallons and gallons would be circulated. The whole point of the return is to provide cool fuel from the tank past the carbs. SUs even have a heat shield. I wonder why???????datmo wrote: I do think the return lines are also a great idea but I feel like if it'll rarely happen, I shouldn't need to worry about making a whole return line for maybe an ounce of gas? more or less.
Re: dual carbs
Plus your 510 should already have a return line. Maybe not 68? But it should. It's a matter of hooking up a rubber line... Not hard.
Re: dual carbs
From what I know, I don't have a return line.izzo wrote:Plus your 510 should already have a return line. Maybe not 68? But it should. It's a matter of hooking up a rubber line... Not hard.
I don't know how to check either.
But as i read, i thought it was rarely that the gas leaked out.
Re: dual carbs
See the black hose on the bottom, and see the spring above the round ridged nut, that is the fuel mixture round nut.
