wheels/tyres
- Cars: DATSUN B110, NISSAN SUNNY
wheels/tyres
HI
I have a Datsun B110 2dr Sedan 1973
12" whells 175/70 tyres (standard brakes, suspension offset 30mm)
and i would buy a 13*6 whells 175/60 tyres but i dont know which offset to buy.
Anyone who have 13*6, please inform me about the offset and if is necessary make any modifaction.
Many thanks on advance
Luis Colchete
Luis Colchete
Re: wheels/tyres
I had 14x7 -10 offest on my B210, they fit. The fronts poked, and the rears rubbed a little.
I'd think you would be ok with 13x6 with a smaller tire too.
Redbanner would probably know what offsets would work
Re: wheels/tyres
The redbanner is the illest of the ill
He is an admin and user on this site. I'm sure he will see this once he comes on and reply.
Re: wheels/tyres
Welcome to NWD Luis
Re: wheels/tyres
Hi!
Many thanks for your greetings and replies
My registration car only allows:
12" 175/70 30mm offset
or 13*6 175/60 which offset?
These dimensions ar not allowed
14*6 175/60 which offset?
15*6 175/60 which offset?
Please inform me, if these whells cause insecurity on driving
If not perhaps i will buy 15*6, and if not inform me if ineed to make any changes and if the tyres rub any point?
Please inform me about the offset of 13*6 175/60
Inform me if these fits on my Datsun sedan B110
http://i.ebayimg.com...ehMw~~60_14.JPG
Luis Colchete
Luis Colchete
Re: wheels/tyres
LUIS COLCHETE wrote:http://www.ebay.com/itm/ROTA-WHEEL-RB-1 ... ea&vxp=mtr
Rotas are really that expensive?
Man. I had no clue.
Where are you from Luis?
Look around and see if you can find some 14" Z car wheels.
Should make for an easy bolt-on, temporary? affair.
Re: wheels/tyres
Hi!
I want only to know what kind of whells 13" OR 14" fitS perfect on my Datsun B110.
Many thanks,
Luis Colchete
Many thanks,
Luis Colchete
Re: wheels/tyres
i Saw 13" whells with 23mm offset,
I saw 14" whells with 15mm offset
I dont know if they fit
Im From Portugal city of Lisbon.
i want the correct information to buy the trough ebay or something like that.
240 z fits on my Dtsun B110?
Re: wheels/tyres
Hi
If the Datsun 240 z Whells fits on Datsun B110 i will loking for them.
Many thanks
Luis
Many thanks
Luis
Re: wheels/tyres
Thank you very much for your ideia.
i will see on ebay 240z and 260z whells.
I wil see minilite whells too. 13", 14" and 15" wide 6 or 6.5 inches.
Anybody have this experience, inform me.
Many thanks
Many thanks
Re: wheels/tyres
Hi!
They will fit on my Datsun 1200 Sedan 2 door Sedan?
http://www.ebay.co.uk/itm/Vintage-Diamo ... 565f3bf065
In Positive way i will bid them
Many Thanks
Luis
Many Thanks
Luis
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
Re: wheels/tyres
Wait b110 or b210?
B210s look good with 13 or 14 inch wheels, and a offset of +15-0 on a 6 inch wide wheel. 0 sitting fairly flush up front.
B110s are tricky. Depends on wich breaks you have.
- RedBanner
Re: wheels/tyres
Im running 13x6 et +18, but when I put new pads in I had to grind a 1/4 inch of the outside of the caliper to clear the wheels. After a week of use the pads would have fit fine, but when brandnew the pushed the brackt out just far enough to touch.
- RedBanner
Re: wheels/tyres
Re: wheels/tyres
Hi
Redbanner
I ve a Datsun B110 Sedan 2 door Year 1973
Thank you for your reply, i ve expecting from you an answer because people of this forum told me that you know best.
According with you 13*6 +8 offset fits with used pads.
And if i cut a piece of outside caliper with a grind, so the outside caliper dont touch the whell.
I m correct? Or if i change some mm the offset? What do you think?
In a local store who sells difrent brands they informe me by phone that 13*6 +23mm fits, in this way i ask an second opinion with a expert person and have a real experience
Many thanks
Miguel
Redbanner
Many thanks
Miguel
