BLUE's Copper ZXT
- Has thanked: 669 times
- Been thanked: 243 times
Re: BLUE's Copper ZXT
062 by 71240z, on Flickr
063 by 71240z, on Flickr
064 by 71240z, on Flickr
Snap-On flat bar. (measuring warpage.. need to look at a couple of other heads while I have it).
Long story short ... have neighborhood politics that kinda limit what I'm doing for the very moment (weird situation) .... this motor was running fine with no knocks before , so I blew out the oil passages/flushed them then decided to assemble. I didn't want to knock anything loose or disturb anything... (engine was kept covered in between). Exception is cleaning up after hone as well.
Sealed Power main bearings.
005 by 71240z, on Flickr
006 by 71240z, on Flickr
007 by 71240z, on Flickr
cleaned caps.
008 by 71240z, on Flickr
009 by 71240z, on Flickr
50% STP/50% oil
011 by 71240z, on Flickr
50% STP/50% oil
crank in
012 by 71240z, on Flickr
rear crank seal lip is cut into the crank , but I decided to move the seal forward a bit (should be fine).
013 by 71240z, on Flickr
014 by 71240z, on Flickr
Cheating and putting the rear-main seal in at the same time (yup dust is collecting on the oil).
023 by 71240z, on Flickr
all main caps on
024 by 71240z, on Flickr
025 by 71240z, on Flickr
all main caps on
026 by 71240z, on Flickr
027 by 71240z, on Flickr
I despise the rear main cap rubber slider thingys/shims system.
028 by 71240z, on Flickr
