75 620 DD for my dad
Eagle_Adam
Re: 75 620 DD for my dad
#61
Post by Eagle_Adam »
but the light turns off at idle......
#62
Correct pulley size?
I recall Ed's 521 alt pulley being too big?
Wouldn't charge at idle, but would when revved.
Is yours too small?
#63
Its charging fine. It was charging in the 13v range at all rpms... Just the light would come on any time above 800 rpm...
#64
That gives me a new idea though... More volt metering!
#65
Isn't 13.0 too low?
If I see anything near 13.6V I'm selling an alternator.
But I also have cars with multiple very expensive computers.
Has thanked: 430 times
Been thanked: 1295 times
#66
Make sure all your wires are good, and I hope you have a internally regulated alt, otherwise it's a nightmare, I gave up on externally regulated alts, I could not get the light to go out the last couple years, even though it was charging fine, but when it did quit, it was a surprise, as I mentioned, the light had been on a couple years.
#67
I didnt say 13.0, I said in the 13s Like 13.5 or 13.7...
Its externally regulated, and in that case I take anything from 13.5 to 14.8 or so. I find the external regulators do as they wish, even with adjustments (mechanical type), and you just have to get one that works right.
It was 13.5 at like 1k with lights, anything above the battery voltage is technically charging.
#68
I see.
Eagle_Adam
#69
so this happened the other day...
in the rain
in the dark
without a jack that would fit under a lowered truck
without a spare tire in the truck
in the middle of an intersection
and i couldn't just drive away cus the fucking U bolts for the lowing blocks were stuck in the asphalt cus i never trimmed them
Eagle_Adam
#70
since i couldnt find a white wall tire to match on short notice i slapped on my spare set of wheels from my 74 that was totaled
i like the black better!!!! but id like to se the white walls make a return soon
Eagle_Adam
#71
always something....
pulled out my spare and tossed it in
#72
amen to that comment. Always something.
Eagle_Adam
#73
Haven't been able to drive the truck for a few weeks......
But I finally got time to work on it today!!!
Ended up that the battery had shit out and one of the front wheel cylinders decided to shit out too....
So I'm ordering parts tomorrow
Eagle_Adam
#74
Brakes came out good, but the work never ends
Developed an exhaust leak...
Off with the carb and mani's
Fresh gasket
Finally added a PCV valve
All better
Eagle_Adam
#75
accelerator pump decided life wasnt worth living anymore....
Eagle_Adam
#76
New accelerator pump is in, fresh carb tune but now I think it needs re-jetted....
Oh well that can wait a while
Eagle_Adam
#77
i just bought a conversion kit for the Weber. I'm tired of the electric choke........
so a conversion kit to run a manual choke is on its way!
#78
Electric chokes are weird. Or rather, Manual chokes are sooooo simple and 100% user controlled!
Brown
#79
Post by Brown »
I prefer manual so much more. good call. I need to change mine over as well.
#80
I prefer manual ones too. But a properly setup weber with electric choke.. You should be able to tap the gas once or twice, turn the key and it works as it should. Something is out of whack, yo!
Locked
