Adam's annoying ass green 620
I think with the Altima cam gets retarded a tooth to change duration. Don't remember.
Been a long time since I have looked it up.
- Eagle_Adam
The cam swap is being done....
And it's a suggestion from a friend that I intend to follow.
Time will tell if it's as good of a swap as he said. Deff cheap
And reversible if I don't like it
Are you planning on doing a before and after comparison? Hard to tell if it's an upgrade if you don't have a base line. I like the idea and I'm sure it has it's advantages or no one would do it. It'd just be cool to get some real world info about the differences from someone (you) who actually knows what they're describing.
- Eagle_Adam
Not sure yet....
Depends on how i like the swap initially. In all honestly it won't take much to swap a cam later
- Eagle_Adam
But jessi did just buy a flipped crossmember....
And she does have a DE in storage
So I could do a side by side comparison I suppose
But I would never have thought of that already .........
- Eagle_Adam
Been busy with my 610 getting it stripped down for paint so there's been little progress on my truck
But!!!!
I did confirm that the heli coil worked and the timing gear is on!!!
So no that my 610 is off for paint tomorrow I'll get back to finishig up my truck.
Stay tuned
But!!!!
Stay tuned
i hear helicoils are stronger then the original hole/threads when done right. IDK if its true... but what everyone says.
Guy at boeing says that they drill/tap, and use helicoil shit on all their bolts as they are stronger than just drilling/tapping a hole.
- Eagle_Adam
The machinist I used has done one in an SR that's still running so time will tell I guess
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
Probably be ready to drop in in the next few days eh?
- Eagle_Adam
Yup, I have a few things I need to square away in Eugene before I can drop it in but I'm close
Dude!
Any updates?
Been a little while, life must have slowed you down a little.
Any updates?
- Eagle_Adam
Ya.....
Life
Vacations
Parties
Ect....
But progress has begun again
Head is torqued for the last time I hope
Idler sprocket is torqued(the one I heli coiled)
I'm sticking with stock cams for now, they are ready to bolt down
Up next I'll get the trans cleaned up and actually install this bitch!!!
But for now this is all you get
Oh ya! I also finally got my metal glove box insert
Life
Vacations
Parties
Ect....
progress is progress! Love it man
- Eagle_Adam
- Eagle_Adam
Guess it's about time to drop my KA in
- Eagle_Adam
It would be good timing, the metal glove box insert is on my to do list
Finally!!
Drop that motor in and slam the ma fucker. looks like it's about to run a rally at a monster truck show
