1979 kc named Lulu
datmo
Re: 1979 kc named Lulu
#61
Post by datmo »
Taterhead wrote:Is it sporadic or constant? Only when getting on it or when idling also?
Sounds like water in the gas to me. Run it empty and see.
someitmes a little bit of both.
and not idle but getting on it.
only when im actually driving. it idles alright but it sounds a bit weak here and there.
Has thanked: 1350 times
Been thanked: 232 times
#62
I'm gonna go with something fuel related. Every time I've had a stuttering problem it's been water in the gas. If you're cruising at a constant speed and it starts stuttering and stops and starts again; 9 times out of 10 it's water.
datmo
#63
Post by datmo »
Taterhead wrote:I'm gonna go with something fuel related. Every time I've had a stuttering problem it's been water in the gas. If you're cruising at a constant speed and it starts stuttering and stops and starts again; 9 times out of 10 it's water.
i replaced my fuel pump but it was not that. I'm thinking it's my distributor? but car is driveable now but occasionally.
RedBanner
Title: MasterBlaster
Has thanked: 2 times
Been thanked: 2 times
#64
Post by RedBanner »
Everytime my shit stutters it has been points. Or condenser.
