MD-Machinst 72-1200 (Mattndew76)
Mattndew76
Cars: 1200 coupe
Re: MD-Machinst 72-1200 (Mattndew76)
#21
Post by Mattndew76 »
Orange = Where I need to pocket groove on either the head or the block.
Green = Where I need to plug.
White = Water passage
Space needle = Seattle from Sunday morning
#22
This is going to be a sweet setup!
Mattndew76
Cars: 1200 coupe
#23
Gotta get these things in a hot tank. Then I can put them in the CNC for mods.
Next up on the order list is the timing component kit. 64.99$ Autozone
Mattndew76
Cars: 1200 coupe
#24
I am playing around with two ideas for the oil feed on the head.
1) Mill a grove pocket into the surface of the block where the orange paint mark is shown in the picture posted prior to this post.. This groove would coincide with the center feed hole on the head.
2)Plug both the block feed and the head feed holes. Then remove the ball bearing plug from either end of the cylinder head oil galley. Tap the existing hole from where the ball bearing was and run a remote pressure line from the Block Galley.
My concern about the remote line is lack of equal pressure that is suggested by the original feeds. That feed from center out rather than end to end.
Would this End to End idea create an over-oil situation on one end of the cam journals and a scavenge on the other?
RedBanner
Title: MasterBlaster
Has thanked: 2 times
Been thanked: 2 times
#25
Post by RedBanner »
Mattndew76 wrote:
RedBanner wrote:It belonged to lildevil after that, then my brother got it fom him, sold it to dave check,
Yeah this poor little car has been passed around like a ward of the state. :rofl:
RedBanner wrote:Fucking wheels.... one job wheel!!
Im glad you got this old beast, me and my brother worked out so many deals toward me getting it over the years, never worked out tho, then he sold it while I was out of state .. but hey, shit came up I guess, cool to see it on the road again. And I lookforward to what kinda bits you make. If you start thinking about making oil pans, let me know BEFORE you get to far into it.
Whatcha got in mind? I will be having to make a dry sump system for the engine I am building.... Well I wont have to make it dry sump. Just kinda wanted to.
What I was thinking is my brother has a nismo aluminum pan, with baffles and windedge trays and exanded capacity, its a great shape other than one dent holding one of the trays closed, and very sought after. And buy the looks of your other parts I bet you could make a duplicate, or better. One.
RedBanner
#26
Post by RedBanner »
http://www.peterzekert.com/for-sale/eng ... d-dry-sump
These guys have wet and dry comp pans, if you wanna picture reference.
Mattndew76
Cars: 1200 coupe
#27
That's where I'm going :D
I will have to machine it from several parts then have my buddy Sam weld it up with the TIG . Haven't started my design yet but had the NISMO pan as inspiration.
Mattndew76
Cars: 1200 coupe
#28
I bought a set of CVK Keihin carbs for the motor project. I think I will try a fitment to the reg A12 to make some manifolds for..
#29
Just a heads up, the brake master doesn't leave much room. I had to get a pretty tight S bend when I made the manifold for my Mikunis. Was worth the effort though. Ran good -- sounded great! Non-issue if you go that route with the Mazda head.
Mattndew76
Cars: 1200 coupe
#30
Thanks for the tip. How long of runners did you go with?
#31
It was years ago. Don't remember if I ever measured. Hope it's okay if I leave a couple pic here for reference.
The rear carb's air cleaner rested on top of the master cylinder's reservoir. Completely stock A15 that I think was a JDM takeout/import.
Mattndew76
Cars: 1200 coupe
#32
No I dont mind at all! reference pictures are needed.
Looks to be 7-9" runner length. Yeah with the Mazda head I shouldn't have an issue.
Tonight I took out the old headliner and took off the sun baked rubber door trim. Doing some deeper investigating of what I have to work with.
What I have found is not impressive.. Looks like the roof was used as a walk way. Its been caved in slightly at some time or another.
Floors are in dire need of some cancer removal. I see nothing less than a total take down, Media blast, and metal work. Typical Datsun tin.
#33
Oh, I like where this is headed.
Mattndew76
Cars: 1200 coupe
#34
These came in today. Cant wait to start design work.
RedBanner
#35
Post by RedBanner »
Ahhh shit, ahhh shit. Yeah! I drove the pumkin around a bit and was extremely impressed with its low end power with long runners, want to try it some day, with a b210 or something I can stand to cut up. Lol
Mattndew76
Cars: 1200 coupe
#36
Soon.....Very Soon.....
#37
So many boners!
Mattndew76
Cars: 1200 coupe
#38
Yeah /i have lots of pre-chub building this.
RedBanner
#39
Post by RedBanner »
Im sharing chubs with you bros.
#40
:rofl: :rofl: :rofl: :rofl:
Oh fuck. coffee out the nose this morning. IDK why... Just effin lolled hard at that.
