Laecaon » Sun Sep 21, 2014 1:08 pm wrote:The cab may need to go back, Its a visual thing, but I think in this photo the wheel is slightly turned and isnt helping anything. But I dont think the cab is moving... The front does need to go up a hair. Oddly enough though, this is the result of using the front cab mounts, as no modification is needed there to get them lined up.wayno » Sun Sep 21, 2014 9:11 am wrote:Center the wheels in the fender wells if you can, in the photo it looks like the cab needs to go back, and the box needs to be forward, is this the cab I suggested that you move the cab forward for fan clearance?
Do you have a valance, I think they look better with it in place.
Is the box going to be a 10 inch extension?
The box... um how do I say, isnt anywhere near where its final position is going to be. Its literally just resting on the frame so its not resting anywhere else. So dont worry...
Yes it has a valence...
The bed is roughly 10" longer, a bit more probably.
The bed hook spacing was the best that could be done. With only extending the bed about 10" the spacing couldnt be exact. Its about 1-1.5" shorter I believe.
Yes the front mounts are basically where they need to be when dropping a 521 cab onto a 720 kingcab frame, but there is a little room to fudge it.
I noticed the wheel looking a little turned, and he mentioned the front needed to go up before fitting the box height, he needs to straighten the wheel and take another photo(hint hint
The truck is looking good, and I am kinda liking the color now, at first I was ho-hum, but I am getting used to it now, like the round headlights on my 720, it took getting used to.
