The connector was melted too. I actually repaired and bypassed (See the wire under the bulb sockets?) some pins for a while and got everything to work. Eventually went with a full set of aftermarket gauges. Could have spliced in a new connector and replaced the cluster and been fine though. Sorry, I don't know enough about 620s to tell you if a '74 and '79 are interchangeable.
