my 77 kingcab
Re: my 77 kingcab
Might be a good candidate for Seafoam. Pull plugs, pour some in each cylinder, let it sit overnight, clear cylinders, reinstall plugs, smoke out the neighborhood. Probably won't cure it but might free up the rings enough so you can buy some time.
- Farmer Joe
Re: my 77 kingcab
gonna see how the money end of the deal turns out..
it anything, i think ill just re ring the DE. when i think about it, the single cam needs a set of lifters and the timing chain at the least. it was getting low on compression too.
if i can just get it to stop suckin down so much oil, ill be in good shape. then i can swap my cams and be done with the engine for a while.
KLH620 KA24DE FS5W71B HF37
- Farmer Joe
Re: my 77 kingcab
got a new video camera.
went with the cheapo SJ4000 non wifi go pro knock off.
for $75 its pretty good. plus i had a $50 gift card, so that helped. lol
- Farmer Joe
- Spoona_Jay21
- Cars: 1978 620 KC
Re: my 77 kingcab
Thats a sweet pic!
Jay needs to do his art work on that one
- Farmer Joe
Re: my 77 kingcab
Cool pics and vid
- K_trip
- Cars: DATSUN
67 Bluebird R16/5spd
71 510 Goon L16/4spd
Re: my 77 kingcab
That video makes for a great sound track!
Your truck sounds healthy when you get on it a bit - nice. The rattles give it some character.
I thought I heard you groan around the 5 minute mark, like it hurt to hit a bump or something.
- Farmer Joe
Re: my 77 kingcab
thanks guys!
lol, it doesnt "hurt", but goin over old railroad crossings does bang ya around a little... haha
the new cams make the top end come on kinda like 2 stroke power... i think its kinda cool how it runs now. sounds a lot better now i hear it from the camera perspective.
Re: my 77 kingcab
I miss that low life. I don't miss that low life ride. Hahaha. the older I get the more into comfy rides I'm getting.
- Been thanked: 1295 times
Re: my 77 kingcab
I like a semi firm ride myself, guess I am used to it because of the work truck, but I cringe every time my frame hits the ground, so I went to great effort to lower the 520 as low as possible without letting anything hit the ground, the only time I hit now is when I go over a big/large/wide speed bump to fast, when it dives off the back side, sometimes the cross member below the oil pan barely touches, and yes I still have trouble with tall little speed bumps in parking lots, I just avoid going over them anymore.
- Farmer Joe
Re: my 77 kingcab
you nailed it.. you remember what ways you can go around town so you dont mess shit up.. lol
ive gotta raise the engine a touch here soon.. its sitting a tiny bit below the engine crossmember, so its hit a few times..
when i get the coil springs in it, ill see if i might be able to run it a little lower with the higher spring rate.. we'll get that worked out later.
- Farmer Joe
Re: my 77 kingcab
dinked around with the exhaust today..
i guess you could call it almost finished....
took a little bit to make the metal look okay. i dig it..
Re: my 77 kingcab
When you get some tires with tread on them, they will hit the exhaust pipe.
- Has thanked: 1350 times
- Been thanked: 232 times
Re: my 77 kingcab
Got a guy down here that did something similar. If I ever see him stopped somewhere I'll get a pic. I always pass him on my way to work. His is a little farther forward with a plate that contours the bottom of the bed.
Re: my 77 kingcab
As promised^^^.
Finally chased him down to get a pic. Shoulda got a pic of the whole truck but I was too busy running my mouth.
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
Re: my 77 kingcab
this is probably the coolest thing, executed in the coolest way possible.Farmer Joe » Sun Feb 22, 2015 2:43 pm wrote:dinked around with the exhaust today..
I love you.
- RedBanner
Re: my 77 kingcab
post those pics again so I can like them more!
