Posts: 2539 Joined: Fri Jun 28, 2013 2:44 pm
Cars: 1969 Datsun 510 - 4 door 1971 Datsun 510 - 2 door 1992 Nissan 300ZX Twin Turbo 2002 Tacoma Double Cab 4x4
Been thanked: 1 time
#521
Post
by draker » Sun Mar 15, 2015 7:52 pm
#522
Post
by draker » Sun Mar 15, 2015 8:11 pm
#523
Post
by draker » Sun Mar 15, 2015 8:19 pm
Anyone have a spare cooling fan to use with a water pump w/ clutch?
#524
Post
by draker » Sun Mar 15, 2015 8:47 pm
Looking for the one on the left:
Posts: 5651 Joined: Wed Jun 26, 2013 6:32 pm
Post
by izzo » Fri Mar 20, 2015 6:13 pm
haha that small blasting cabinet is awesome
#526
Post
by draker » Sat Mar 21, 2015 8:24 pm
Still looking for a fan.. and clutch. Or just a fan and the pulley.. Ni10 might have one that'll work. I need to measure shit and figure it out.
#527
Post
Cracked open the Ospho.. brushed it on. Pictures are worthless... but here you go!!
#528
Post
by draker » Sat Mar 21, 2015 8:25 pm
#529
Post
by draker » Sat Mar 21, 2015 8:28 pm
It already started to bubble a bit... so it's working. But you can't see it in the pictures..
Next up.. either more sand blasting or I'll spray the ospho treated areas.. I need assemble the "blasting" booth again. This time it will be a spray booth..lol. Then I need to figure out if my cheap harbor freight HVLP gun is worth a shit for spraying primer. I'm such a HVLP noob..
#530
Post
by draker » Thu Mar 26, 2015 9:40 pm
#531
Post
by draker » Thu Mar 26, 2015 10:09 pm
Next steps..
Strip the entire drivers side rear quarter and spray with zero rust.
knock out some dents in the quarter
Filler and block
Epoxy primer
Once it's in epoxy.. I might leave it there until after Canby. We'll see how much time I've got.
#532
Post
by draker » Thu Mar 26, 2015 10:19 pm
Also my HF HVLP gun sounds like a dying duck.. I don't think that's normal.
Posts: 7699 Joined: Thu Jun 27, 2013 7:05 pm
Has thanked: 1210 times
Been thanked: 1180 times
#533
Post
by DRIVEN » Fri Mar 27, 2015 5:05 am
Post
by izzo » Fri Mar 27, 2015 5:53 pm
Wow!!
That's looking tons better man. Keep it up. It's gonna look good just in primer alone
#535
Post
by draker » Sun Apr 05, 2015 9:50 pm
I was able to find a fan. It's a fixed blade with no clutch. Seems to be fine. I do like fan clutches though.. especially when you forget your wrench on the crank bolt. lol
I got everything back together today and was able to start it up. The engine still vibrates pretty good, even after installing new stiffer mounts. I'm not convinced it's running right. It's probably about 80%. I'll probably get it nice and hot and adjust the valves again and see where that gets me.
#536
Post
by draker » Sun Apr 05, 2015 9:53 pm
I have a HF HVLP gun.. but the tip is too small for spraying primer. Also the gun is really not that great. It functions.. but I wouldn't use it for anything but primer.. and since the tip is too small for primer.. it's not really useful.
That being said, I bought another gun today. The Devilbiss startingline with a 1.8mm tip:
#537
Post
by draker » Sun Apr 05, 2015 9:55 pm
When I do color and clear, I'll use a SATA.
Posts: 9706 Joined: Wed Jun 26, 2013 6:44 pm
Has thanked: 6 times
Been thanked: 7 times
Post
by 510freak » Mon Apr 06, 2015 6:33 am
Sata's are awesome
Post
by izzo » Mon Apr 06, 2015 8:59 am
what do you think the engine issue is?
#540
Post
by draker » Mon Apr 06, 2015 1:09 pm
Fuel or valves. I'll get it toasty hot and compression test it again. Then adjust the valves if needed. If still crap... back to the fuel.
On the plus side.. I confirmed the weber I have is jetted for the l16. At least it's jetted to the weber baseline. I found the Jets were swapped from the primary and secondaries. So I fixed that. Still lugs from idle if you punch it.
More work to do..
